• 23.11.2026, 00:31
cypriobrit
Correct mount for Cuplex Di
Saturday, August 11th 2007, 3:11am
I see there is a thread in the german watercooling forum about the correct way to mount your cuplex on a dual core CPU - could someone please translate the final outcome of what way to mount it?
Google translator didnt help much!
Thanks
gr3if
Re: Correct mount for Cuplex Di
Saturday, August 11th 2007, 3:52am
Look at my sgnature ;D
When can see a silver thing inside the Di there is the inlet and when u can face cooper there is the outlet.
cypriobrit
Saturday, August 11th 2007, 7:51pm
Thanks - but i meant the way you mount it in the motherboard.
Should the inlet/outlet be above each other or side by side? There was some discussion about the positioning of the cores under the heat spreader of the CPU i think.
Hope that is clearer.
gr3if
Sunday, August 12th 2007, 3:55pm
Which Cpu do you have? It depends on your die.
cypriobrit
Sunday, August 12th 2007, 4:16pm
a 6400 core duo.
