• 18.11.2026, 15:31
xesperto
Tubemeter with Aquaero
Sunday, August 26th 2007, 1:19pm
Hi all !!
i have a aquaero 4.0 and a tubemeter !!
when i´m going to see in the aquasuite i have 2 main TABS, the first is the aquastream TAB and the second is the tubemeter Tab, but in the firts( Aquaero) i don´t see the tubemeter settings !!!
what is wrong !?
thks :D
Infiltraitor
Re: Tubemeter with Aquaero
Sunday, August 26th 2007, 5:17pm
I'm still using all the tabs in my Aquasuite - the tubemeter doesn't appear on my Aquastream tab either; it's on the Overview tab.
xesperto
Sunday, August 26th 2007, 5:29pm
Yes its in the overview page !!! but it´s does not work !!!! it´s simply dead :(
but in the other hand in the tubemeter tab it seens to work just fine !!!!
i have connected it directly to a USB connection is it right !? or i need to connect to the Aquaero directly !? if so !? how !?
thsk
Infiltraitor
Sunday, August 26th 2007, 6:07pm
Ah, right - I see.
What version Aquasuite are you running?
xesperto
Sunday, August 26th 2007, 10:28pm
i´m running 4.43 !!!
Infiltraitor
Sunday, August 26th 2007, 11:42pm
So on your Aquaero display (LCD or VFD), the water level is displayed okay? Assuming you're not running the Lite version.
Have you tried uninstalling Aquasuite and reinstalling it?
Top_Nurse
Monday, August 27th 2007, 2:10am
Aquasuite => aquaero => Return to default settings.
Does this help out?
xesperto
Monday, August 27th 2007, 11:58am
it does not display nothing in the aquaero !! ( LCD)
just a question !! the Tubemeter it supose to be connected to a USB Port right !?
gr3if
Monday, August 27th 2007, 1:02pm
yep
xesperto
Monday, August 27th 2007, 1:05pm
thks !! just Checking !! ;D
Infiltraitor
Monday, August 27th 2007, 6:52pm
My Tubemeter is connected to the header pins in my Aquaero.
xesperto
Tuesday, August 28th 2007, 12:01pm
header pins ? where !? sorrry i´m rookie on this !! :D
melon
Tuesday, August 28th 2007, 12:40pm
You can choose between the USB connection or the header pins of the Aquabus:
btw
If you want to connect the Tubemeter to the Aquabus, you have to buy the optional connection Cable: 93266
(Ps: man kan über treiben)
