• 06.10.2026, 01:23
optimadam
Aquaero and aqua suit
Monday, August 27th 2007, 12:34am
Im trying to get my fans to increase in speed as the temp increase. At the moment they jump between speeds and when the speed maxed they take ages to drop back down.
Not quiet sure what im doing wrong.
Its all seem delayed
Thanks
Adam
Top_Nurse
Re: Aquaero and aqua suit
Monday, August 27th 2007, 2:12am
Did you read the manual? The manual tells you how to adjust this kind of stuff. Kinda... ;)
divve
Tuesday, August 28th 2007, 9:11pm
Let us know what your current setup, settings, and relevant temps are. The ambient air operating temp range is important to know as well.
Personally I've found that I had to set the Reference value and Max limit with-in 2C of each other. In my instance it allows my system to run quietly in almost all occurring ambient room temps and respond properly to heavy loads. Some lag in the response is okay though. One of the virtues of water cooling is the capacity to absorb heat without immediate faster fan response.
optimadam
Tuesday, September 4th 2007, 11:23pm
Hi, ive fixed it now. I had it set to change with temp and i wanted it to be controlled by progressively
