• 26.11.2026, 00:30
Announcement: aquastream XT
Friday, August 3rd 2007, 7:51pm
In approx. 8 weeks we will introduce a strongly revised pump.
This will be increased considerably in the functions and in the performance range. Electronics is integrated into the pump now and among other things there is a USB interface - of course with integration into the aquasuite software.
At the other functions we would not like to betray too much yet.
Since our stock levels of the current revision are low, it is very likely that we will not be able to deliver any pumps for a short time. We ask to take this into account.
edboswell
Re: Announcement: aquastream XT
Friday, August 3rd 2007, 8:42pm
any information on the size?.. smaller or larger than the current aquastream etc.?
Friday, August 3rd 2007, 8:53pm
It is still based on the Eheim 1046, so I think there will be no big differnce in size.
Top_Nurse
Saturday, August 4th 2007, 12:47am
How much better flow and how quiet?
Will you be able to adjust the flow rate (or pump speed) in reference to the temp sensors or the flow meter?
heed
Thursday, August 9th 2007, 8:31pm
Shoggy, Stefan, et al., are there any new details on the new pump?
Thursday, August 9th 2007, 8:35pm
Ask again in ~7 weeks ;D
gr3if
Saturday, August 11th 2007, 3:56am
From German Forum:
The new Pump will have the ability to increase flow rate or be quiet the electronic can be adjusted like that.
Every Aquastream can be equipped qith xt electronic and Yeah wait 7-8 Weeks.
Top_Nurse
Saturday, August 11th 2007, 6:18am
Any thoughts about also selling new controller boards for those of us who have older style Aquastream pumps?
Saturday, August 11th 2007, 11:16am
Yes. An upgrade will be available.
x-stars
Wednesday, August 15th 2007, 12:48am
...but with some minor differences (as announced in the german section: some small features cannot be used on upgraded old-version aquastreams - but nobody mentioned what features that will be :'()
Ptimousse
Sunday, September 2nd 2007, 2:35am
Hello,
I would like to know if it will still be possible to submerge the pump, without losing any functionality. Also, will the aquastream XT come along with an aquaero XT ?
Regards,
Ptimousse
Sunday, September 2nd 2007, 2:47am
Welcome to the forum :)
Sorry, but you can't submerge the new XT version.
And no, you won't see an aquaero XT.
The aquastream XT can be connected to a normal aquaero.
By the way: it will be possible to upgrade ALL aquastream versions to a XT version (with small limitations).
divve
Wednesday, September 26th 2007, 11:19pm
I just saw the new Aquastreem XT in your shop. Very nice! Now that it's been released could you tell us how and what would be required for the upgrade of the previous version of the pump. Also, will it be able to go all the way to 100hz as well?
...BTW, i don't care it's so nice I'll buy the XT if i means I won't have to wait for a few months :)
pharao
Wednesday, September 26th 2007, 11:21pm
Quoted from "divve"
you won't have to ;)
divve
Thursday, September 27th 2007, 4:42am
If I understand it correctly you connect the pump directly to your PSU by a 4-pin molex and USB to the mobo. Then, control it with the Aquastream XT software. This is great for autonomous operation or for a second loop in your PC case.
However, I'm currently using an Aquaero with the Aquasuite software. From what I understand the software will also recognize the new pump, but will it be able to run it to the maximum of 100hz, or will I have to do it through the new XT software?
gr3if
Thursday, September 27th 2007, 9:42am
Via Aquaero you can set the pump to 100h frequency.
Thursday, September 27th 2007, 5:07pm
Sorry, I currently have no time to translate the text.
It should be translated till Sunday :)
divve
Thursday, September 27th 2007, 5:25pm
One more question, when the XT pump is connected through the Aquabus to an Aquaero, is the USB connector still necessary for any type of function?
Thursday, September 27th 2007, 7:24pm
Yes, because a lot of settings can be done only through the aquasuite.
You won't need a USB connection at all but then you will miss some of the nice features ;)
divve
Friday, September 28th 2007, 12:43am
OK thanks. The integration of controller and software is one of the great strengths of Aqua Computer. Hopefully there will also be an update to the Aquasuite software so all parameters can be set within the same program. Once I've tested everything I'll report back with my findings.
