• 01.11.2026, 16:56
wiking
Aquasuite - Emergency Shutdown
Monday, October 29th 2007, 9:26pm
I have just installed a tubemeter and a poweradjust LT in my system, and everything is working perfectly.
The tubemeter emergency shutdown function is neat.
I have also connected a Innovatek flowmeter rev 3.6 on the poweradjust and flow is showing nicely. Enabling the flow alarm gives a low flow error message, but nothing more. Can you upgrade the aquasuite with an "emergency shutdown" function, like on the tubemeter, in the next revision (shutdown on low flow and pump failure) ?
divve
Re: Aquasuite - Emergency Shutdown
Monday, October 29th 2007, 9:37pm
I don't know whether it works with that sensor. However, with the sensor they sell you can set the flow alarm under the Flow Sensors tab in Aquasuite. Then, check Flow Alarm Sensor which can be found under the Alarm & Relay tab.
gr3if
Monday, October 29th 2007, 11:23pm
First got there then set to emergency shutdown. Then:
Tell the Aquasuite which sensor.
wiking
Monday, October 29th 2007, 11:41pm
Thank you both, but as I am running poweradjust and tubemeter, I don't get all of that options, only tubemeter and poweradjust.
The flow meter is working perfectly.
I would like that anyone from Aqua-computer could give me a feedback on this, as is is a matter of changing the software.
gr3if
Monday, October 29th 2007, 11:56pm
No its not. I have an Aquaero Lt. So this option only pops up when an Aquaero is present which can handle the shutdown.
