• 20.10.2026, 18:38
edboswell
Aqastream front plate question
Tuesday, November 13th 2007, 6:44pm
Hi I just bought the aquastream XT - while I used to have the aquastream with the flate plate (e.g. with the 2 led lights etc.)
Now do I have to use this front plate with the new aquatream XT or shouldn't I use it at all or is it optional?
Thanks
Ed
Re: Aqastream front plate question
Tuesday, November 13th 2007, 6:51pm
The aquastream has all their electronics on the back, no external circuit board is needed anymore. There is also no way to use that old board with the XT pumps.
edboswell
Tuesday, November 13th 2007, 7:25pm
ok thank you for your quick answer :)
But how about the aquaero, is this connected to the aquastream XT?
Tuesday, November 13th 2007, 7:43pm
You can connect the aquastream XT via aquabus.
The necessary cable comes with the pump :)
edboswell
Tuesday, November 13th 2007, 7:45pm
ok thanks.... and am I right in thinking I then don't have to connect it via USB..(to the motherboard)
- sorry just want to make sure I get everything right 100% :)
Ed
Tuesday, November 13th 2007, 7:48pm
You should connect it also to the USB because without that connection you will miss a lot of features.
edboswell
Tuesday, November 13th 2007, 7:59pm
ok so use both. Anything else I need to connect to get the features of....my setup:
aquastream xt
several blocks
360 xt
the new aquacomputer flowsensor
sorry...I am only asking because there are quite a few connectors on the back of the aquastream xt and it doesn't come with a manual.
Thank you again
Ed
gr3if
Tuesday, November 13th 2007, 8:28pm
Hm the manual is there but only in german. Do you want to know something special? I would translate it.
edboswell
Tuesday, November 13th 2007, 8:33pm
I did not get a manual with mine German or English...but this doesn't really bother me...I just want to know if the connectors called "fan" and "rpm" and "ext.temp" need a lead to go into something or not (in order to get everything out of the aquastream XT)
Thanks
Ed
ps I am still setting everything up this is why I havn't looked for myself in Aquasuite to see if everything is working.
gr3if
Tuesday, November 13th 2007, 8:39pm
On the fan thing you can connect fans to the pump. You can connect a flowmeter to the pump and you can connect one temp sensor to the pump.
Everything the pump can controll the aquaero can do too.
So normally connect the As Xt via Usb to the mobo and connect everything else to the aquaero.
edboswell
Tuesday, November 13th 2007, 9:11pm
ok thank you for your answers :)
edboswell
Tuesday, November 13th 2007, 10:07pm
Sorry - one more question.
I am filling the system and the aquastream has a flashing red light...what does this mean? trouble?
Ed
gr3if
Tuesday, November 13th 2007, 10:09pm
No the light should normally blink. Than its perfect...
A bit confusing maybe a firmware update will fix this but atm the pump is fully okay if the red light is blinking.
Tuesday, November 13th 2007, 10:33pm
In the next firmware the red LED can be turned off.
edboswell
Tuesday, November 13th 2007, 10:45pm
hehe ok thanks
yer it is a bit confusing...red flashing normally means high danger lol.
Ed
gr3if
Tuesday, November 13th 2007, 11:38pm
Yeah some guys in the german part wondered about the same thing. Well see what happends but normally Ac can fix anything ;D
