• 06.10.2026, 15:38
grover
AETray Windows Monitoring Tool *Version 0.2.0*
Friday, November 2nd 2007, 11:10am
AETray is a monitoring software for the Aqua Computer aquaero 4.00 for Microsoft Windows. The software adds an icon into the notification area (aka system tray) of the taskbar. The icon displays the status of all attached aquaeros and provides further status information, if the user hovers over the icon with the mouse.
The software provides read-only status information for your aquaero devices using only approximately 300kb of memory. Much less than running the AquaSuite (>20 MB) for the same monitoring purposes.
Use this software to receive status notifications, if your computer is beneath your desk and/or out of sight like mine. Also very useful for aquaeroLT owners.
Status window
Error notification
Status window with error highlights
Features:
- Standalone 52K executable (18K download)
- Uses approximately 250K RAM
- Supports any number of connected aquaero devices
- Supports Plug'n'Play: aquaero are detected and used at runtime
- Status-Window: Displays details of all sensors, fans, flow meters und aquastream pumps
- Error notification: See errors, where you're looking at - the screen.
- Now with English UI for US and UK users. Others, please read the FAQ.
System requirements
- Windows XP (others not tested, should work with Windows 2000 and above)
- Visual C++ 2005 SP1 Runtime Libraries (are required only once, usually already installed due to .NET 2.0/3.0 or other Programs.)
- 300K RAM
- at least one Aquaero
Links:
- Current Version: 0.2 built on November 6th, 2007
- Version: 0.1 built on November 1st, 2007
- AETray Homepage
Have fun and reply if you experience problems, want to request features or share your experiences.
Mike
JorisS
Re: AETray - new Aquaero Monitoring Tool for Windo
Friday, November 2nd 2007, 12:47pm
Nice work! I'll see if I give it a go or wait in the English version first.
Max_Payne
Friday, November 2nd 2007, 10:17pm
also ich hab es mal eben unter Windows Vista Home Edition Premium (32-Bit) ausgeführt, und es lief einwandfrei.
Allerdings vermelde ich auch gleich einen Bug, und zwar bei ist an den Sensorkanälen 3 + 4 am aquaero kein Fühler angeschlossen, und das AETray wertet dies als Fehler aus:
Was mich ebenfalls wundert ist, dass bei mir der Sensor 2 eigentlich Wasser out heißt, dies aber nicht vollständig angezeigt wird. Und zu guter letzt, wäre es möglich, dass das Tool noch zusätzlich die aktuelle Frequenz der aquastream anzeigt ?
Fazit: Sehr geniales Tool :D 8) 8)
Gruß Max Payne
grover
Friday, November 2nd 2007, 11:08pm
@Max_Payne
Den Bug mit den Temp-Sensoren habe ich bereits gefixt. Den hat Shoggy schon im deutschen Thread im Überwachungs-Forum gepostet. Im nächsten Build ist der weg.
Wegen der Schriftgröße bin ich noch am grübeln - ich hab da keinen Layoutmanager dahinter. Die Texte sind einfach "statisch" da... :|
Zur Frequenz: Wenn Du mit der Maus über den graphischen Balken gehst, siehst Du alle Details der Aquastream in einem Tooltip. In der 0.1 ist da allerdings noch ein Bug drin, da zeigt es die Frequenz nicht richtig an. Der ist auch schon behoben - ich grübel nochmal ob ich die Frequenz in den normalen Dialog mit aufnehme.
Danke fürs Feedback :)
Max_Payne
Friday, November 2nd 2007, 11:15pm
Ahh ;D ;D jetzt hab ich den deutschen Thread auch gefunden.
Ich poste da mal weiter ...
Gruß Max Payne
taloche_aqualite
Sunday, November 4th 2007, 3:28pm
Et si on faisait espre de me pas ecrire en anglais ? ;D
grover
Sunday, November 4th 2007, 3:54pm
I'm sorry my french is a bit dusted. If you're asking for the english version I'll release it soon. If you want to provide a translation to your language - it'll be very easy.
taloche_aqualite
Monday, November 5th 2007, 9:33pm
no, i just ask to write in english in english forum ...
gr3if
Monday, November 5th 2007, 11:40pm
Max didn' t found the german thread so he posted here.
grover
Re: AETray Windows Monitoring Tool *Version 0.2.0*
Tuesday, November 6th 2007, 3:26am
I have decided to upload Version 0.2 of AETray. It may have some bugs, which I'll squash if you report them to me. This version adds english translations for UK and US users. If you're not from the above countries you may want to look at the FAQ (below) to help me translate it to your country/language.
Anyways, here's the change log:
- Visual C++ Runtime Library is not required and not used anymore
- aquaero alarm register is evaluated and failure notifications displayed for those errors.
- Missing temperature sensors do not cause failure reports
- No flow meter #2 errors generated if Fan4 header is used for a fourth fan or unused.
- Better detection of missing fans (see FAQ)
- Better detection of missing flow meters (see FAQ)
- Broken tooltip for fan1 fixed
- Added english translations for US and UK users
- Added support for different languages. (see FAQ: How can I translate AETray?)
- Aquastream frequency display corrected and frequency is displayed in status dialog if aquastream status is ok
- Display of values and physical units in tooltips corrected
- Failure report balloon tooltips are displayed every five minutes (instead of once.)
- Double clicking AETray icon launches AquaSuite
- Better asynchronous communication with aquaero
- Synchronizes aquaero clock to clock of the PC.
The memory requirements are a little higher, but they'll go down again. ;)
I've compiled an FAQ for all problems encountered in Version 0.1. Please read it, if you encounter problems as the answers are still valid.
Here's the download link.
grover
Tuesday, November 27th 2007, 3:55pm
Ralph Candau has provided me with a french translation of AETray. Thank you very much Ralph!
Download
(AETray 0.2 needs to be downloaded seperately, the download link only contains the french translation.)
