• 05.10.2026, 16:56
New: aquaduct mark II series
Monday, November 26th 2007, 12:34am
We would like to introduce the new revision "mark II" in this place a year after the presentation of the aquaduct series. Within the last year we got much feedback and wishes and have tried to integrate these as far as possible. Some things were already changed within the last months, others will go with "mark II" in production now. Hardly visible almost every component of the aquaduct was improved or revised.
The changes of the aquaduct 240 are particularly interesting. This got a USB interface as well as an integrated fan control and the possibility of attaching a flow sensor. The compact design was kept.
New features of the aquaduct 360 XT mark II
  • Connectivity for two additional temperature sensors on the enclosed PC circuit board. The measurements of these sensors can be used variously in the control unit.
  • Completely new control with installation assistant
  • Knob with "one touch control". All attitudes of the control unit can be carried out userfriendly over the knob.
  • Override function: By pushing and turning the knob simultaneously the aquaduct can be adjusted between a powerful "performance" mode and an almost "silent" mode.
  • Acoustic alarm signalling system. A built-in loudspeaker distributes an acoustic signal with alarm and generates a key click at changes of the settings.
  • Connectivity for an additional fan on the enclosed PC circuit board. For example a case fan can be controlled via the aquaduct with that.
  • Configurable speed signal output. At connection to a fan header of the Mainboard an emergency shutdown of the PC can be carried out via the BIOS. The available relay output can in addition be used for various alarm functions.
  • Improved decoupling of the integrated Eheim pump
  • Pump drive optimized: Automatic "overclocking" and rotation detection were integrated. The maximum frequency was increased and the smooth running of the pump was improved through an adapted programming.
  • A changed channel flow in the bottom of the new aquaduct allows an much easier deaeration of the integrated pump.
  • Graphic representation of the device with the essential control parameters in the enclosed Windows software "aquasuite".
  • Air flow optimized rear installation of the fans
  • Increased flow by a new construction
Further details are the 15-pole connector cable and the counter-sunk plug at the bottom. Of course the circuit board in the PC was also revised completely.
New features of the aquaduct 240 PRO mark II
  • Integrated control with USB connection
  • aquasuite software for the control and regulation of the fans
  • Two integrated temperature sensors measure both water temperature and the air temperature. The micro processor-controlled fan control offers many regulation options.
  • An optional flow sensor can be attached on the enclosed PC circuit board. The measurements can be displayed and evaluated of course in the Windows software.
  • Rotation detection and improved decoupling of the integrated Eheim pump
  • Automatic "overclocking" of the pump can be activated in the software.
  • Simplified filling and deaeration by a new construction
  • Acoustic alarm signalling system, a built-in loudspeaker distributes an acoustic signal with alarm
New features of the aquaduct 240 mark II
  • External voltage regulation for the fans
  • An analogous fan control unit for the direct control of the fans is contained in the scope of delivery.
  • Improved bottom structure
  • Improved pump decoupling
Aquaducts ordered in advance are delivered without surcharge in the version mark II. The aquaduct 360 XT mark II will be available within approx. 3 weeks, the other types are available as of now.
A few pictures and screenshots:
(The aquasuite software is also available in english)
Top_Nurse
Re: New: aquaduct mark II series
Tuesday, November 27th 2007, 1:14am
Did you get rid of the extra 6 feet of tubing by rerouting the internal parts?
Tuesday, November 27th 2007, 11:23am
Yes - we have changed the internal way of the water also inside the bottom plate.
Tuesday, November 27th 2007, 11:25am
Tuesday, November 27th 2007, 9:42pm
Ooops ::)
Here ist the english thread :)
