• 29.11.2026, 00:49
Rockwool
Water temps
Sunday, December 30th 2007, 1:12am
How hot are you running your water ?
My water is around 29 (idle) to 31(full load).
there should run around 5,5l/minut thru the system.
My system is build up so the water is running thru my pump and split in to two pipes. both thru my hdd cooler (5 discs), going to the MB blocs mosfets and nb and sb. going in to one pipe end thru my cpu cooler, thru a tubemeter at in to my radiator. my fans is running 600rpm and im having a 360mm radiator.
I have just bought a Gigabyte Odin GT 800W psu and a asus 8800gt 512mb top grafic card. im vant them both water cooled. that is about 250W more i have to deal with. im thinking om taking the water after the cpu then thru the psu and then the 8800gt.
So Im thinking on just let the water temp rise so i dont get more noise. but is it a good idea ? my hdd's is so essential. I have enen a little idea where they get there own pump an radiator. but im almost out af space.
My final question is still how hot do you run your water and your adient temprature.
Regards
Miyoshi
Re: Water temps
Monday, December 31st 2007, 6:00pm
My water is running on 33(load) 28-29(idle) and my air temp is at 25.
My setup:
Q6600 G0@3,6 GHz 1,375 V
Gigabyte GA-X38-DQ6
OCZ Titanium VX2 PC-8000
Inno3D GTS 512
My cooling:
Cuplex XT di
2x Ramplex
2x Twinplex XT di
Aquagrafx G92
MIPS block for the regulators (AC doesn't have one that fits my MB)
Aquastream XT, Airplex XT 360 and 3x Airstream
Aquaero
