• 18.11.2026, 20:38
7HUND3R
control fan aquaero and aquasuite
Wednesday, August 15th 2007, 8:31pm
hello.
I have a doubt with auqaero, is that the ventilators I have them controlled by the software of aquasuite, I have all the ventilators then 50%. when enchego the PC the ventilators is put to the 100% and they do not put to 50% spear that the profile did not load. it always does not regulate them to 50%?
divve
Re: control fan aquaero and aquasuite
Thursday, August 16th 2007, 3:49pm
You can try saving your settings to the EEPROM through the Aqua Suite software. If that fails try resetting the Aquaero by holding down the set/mode button for 3 sec. from a complete power off boot.
7HUND3R
Tuesday, November 20th 2007, 1:01pm
I mean if aquaero can control the fan hardware and not software.
You can control hardware?
divve
Tuesday, November 20th 2007, 1:34pm
Yes. After the settings are saved to the Aquaero, it'll control the fans by itself without the Aquasuite software. Alternatively, you can program the fan settings directly into the Aquaero as well
7HUND3R
Tuesday, November 20th 2007, 10:19pm
As the fan is controlled by the aquaero?
divve
Wednesday, November 21st 2007, 1:32am
The Aquaero controls everything. That's what makes it great. It works independently from your computer's OS. For instance, if your computer locks up when unattended the Aquaero still can perform an emergency shut down and save your hardware from overheating.
7HUND3R
Wednesday, November 28th 2007, 1:50pm
If I was that aquaero has many functions, but I want to know the steps we need to do to control fans with aquaero and not aquasuite.
gr3if
Wednesday, November 28th 2007, 3:52pm
What?
You have to connect the Aquaero via Usb to your motherboard then you can access all features through the Aquasuite. There is no other way.
7HUND3R
Friday, November 30th 2007, 1:38pm
But des del aquaero can not? That is when I turn on the pc fans are put at 100% and I have to load acuasuite to be regulated as I want.
gr3if
Friday, November 30th 2007, 2:01pm
Try to save your settings in the EEPRom. Then it should work.
7HUND3R
Friday, November 30th 2007, 7:54pm
Not how.
gr3if
Friday, November 30th 2007, 8:11pm
Could ypu please write in a proper English what your question is?
At the moment i can' t get it.
7HUND3R
Monday, December 3rd 2007, 8:21pm
As I regularly fans through the aquaero, I do not want to regulate the fan with aquasuite.
gr3if
Monday, December 3rd 2007, 11:56pm
Okay. You have to make your settings how the fan should be controlled in the Aquasuite. Then you have to hit the button save settings in the eeprom. Afterwards you can disconnect the Aquaero from Usb. It will work with the settings given.
Top_Nurse
Tuesday, December 4th 2007, 3:53am
Quoted from "7HUND3R"
If I am understanding you correctly, you want to control the Aquaero fan headers though the hardware correct?
If so it is a pain, but can be done via the three buttons on the Aquaero. Then you save the settings via an eprom write and you are done. You don't have to use the Aquasuite software.
As gr3if mentioned above, the fast way is to use the Aquasuite
to program the Aquaero and then you don't need it anymore.
7HUND3R
Wednesday, December 5th 2007, 12:49pm
If I want to control fans with the three buttons aquaero. But not knowing how to do. I have to load des profile of aquasuite.
7HUND3R
Monday, December 31st 2007, 12:26pm
help please?
gr3if
Tuesday, January 1st 2008, 3:51pm
