• 29.11.2026, 04:03
lemmy64
First Time Starting Aquero: Loading OS....
Saturday, January 12th 2008, 6:33pm
First Time I started my aquero it says Loading Os....
then after about 2 min the screen goes off
Then the fans start turning on and off
What is going on? Please help
Re: First Time Starting Aquero: Loading OS....
Saturday, January 12th 2008, 7:48pm
Welcome to the forum :)
Do you get a connection via aquasuite?
Maybe you should try a reset. Shutdown your PC, then press and hold the set-button and start your computer. After ~2 seconds you should see a reset message in the display. Now you can release the button.
lemmy64
Saturday, January 12th 2008, 8:41pm
thanks for fast response,
there is no connection via aquasuite
I hope i Hooked up USB right to Mobo
I know the pin order is correct just don't know if it is on the N.C. side or the Key side of the motherboard usb input I have.
But I did try the reset, I saw it say reset right when i turned on the computer, but then it went back to Loading OS... then after that the same thing. Turns off and fans go on and off variably.
lemmy64
Saturday, January 12th 2008, 8:56pm
it seems like the aquasuite does detect the aquero, but i don't see any accurate readings in aquasuite
I saw USB installed earlier,
I tried doing FLash, when I did turn it on the aquero said press enter to flash, so i pressed the setup button. I hope that was correct.
But after waiting 15 seconds for restart still nothing
lemmy64
Saturday, January 12th 2008, 8:59pm
here is a screenshot of my aquasuite
http://img172.imageshack.us/img172/1669/aquero3xh2.jpg
My aquastream is connected to my aquero but doesn't detect it in aquassuite.
Saturday, January 12th 2008, 9:00pm
After flashing you(!) have to restart, the aquaero won't do that because it can't ;)
So shutdown the PC and start it again. A simple restart will not work.
lemmy64
Saturday, January 12th 2008, 9:01pm
I can also see the RPM fan reader #'s moving but on main aquasuite screen it says 0%
http://img174.imageshack.us/img174/834/aqua2ae3.jpg
lemmy64
Saturday, January 12th 2008, 9:02pm
Yeah i Shut it down for 15 seconds and waited
even turned off powersupply for 30 seconds
Still same thing
Saturday, January 12th 2008, 9:03pm
49510 rpm - LOL ;D
Does the aquaero itself still not work correctly? Because that is would be your main problem. If the aquaero does not work correct, the USB and aquasuite will also not work correct.
lemmy64
Saturday, January 12th 2008, 9:07pm
Yeah the aquero it's self is not working correctly =/
It keeps turning off after 2-3 min
What would be the next step?
lemmy64
Saturday, January 12th 2008, 9:17pm
Am I suppose to connect a power connector to the aquabus extension? I never did could that be the problem?
Only power connector connected is to the Aquero
I did not connect one to the aquastream as I read some people said not to.
But in manual it says both?
Saturday, January 12th 2008, 9:19pm
The only power connection is the 4-pin molex connector - nothing else.
lemmy64
Saturday, January 12th 2008, 9:22pm
So only power needed is to the aquero no where else?
lemmy64
Saturday, January 12th 2008, 9:39pm
Well something good happened
I disconnected everything except Power to quero and the aquastream cable.
So far so good, I can see firmware on my aquero is 4.09 should i Update it?
lemmy64
Saturday, January 12th 2008, 9:59pm
I am happy to announce that it is now working!!!!!!!!!!!!!!!
Can you tell me what latest firmware I should have?
Saturday, January 12th 2008, 11:24pm
4.13 is the latest version.
