• 29.11.2026, 14:54
Guffen
Aquastream XT ULTRA, Aquastream 1.07 and Aquaero?
Friday, February 1st 2008, 1:47pm
The Aquaero say that the firmware is to old? I have flashed both the aquaero and the XT pump.
Still the Aquaero say that the firmware is to old. If i use them seperate it works fine.
Is there any way i can fix this?
Re: Aquastream XT ULTRA, Aquastream 1.07 and Aquae
Friday, February 1st 2008, 2:12pm
Am I right that you have two aquastreams? One XT and a V1.07?
Please go into the pump and flow rate settings of the aquastream XT (in the aquasuite) and set the aquabus adress to 11. Save the settings into the pump and now it should work.
Right now it is very likely that both pumps use adress 10 which will not work correctly.
Guffen
Saturday, February 2nd 2008, 12:24am
Quoted from "Shoggy"
That was correct, but still got the Firmware to OLD message, and i can not set any speed for any pump. And the XT pump will not send the water temperature sensor data to the aqaero.
The aquaero has firmawre 413a
The XT ultra pump has : 1005
The old aquastream has rev 1.07?
Can I use all this togheter? Can I add a tubemeter too?
