• 29.11.2026, 17:25
johnolg
Aquastream XT Ultra
Monday, February 25th 2008, 12:31pm
Hi Guys
Just got my Aquastream XT Ultra and I am having a problem with the frequency setting.
If I set the Aquastream to "Automatic frequency settings", it spends about 5 minutes trying to find its optimal frequency before settling at about 80Hz. at which it vibrates a lot and is very loud. After a bit of trial and error I found its best setting (for noise) seems to be 58Hz. My questions are:
1. Is this normal?
2. Can I damage the pump by manually setting the frequency?
Ive updated the Firmware to 1009 which made no difference
Thanks for any Help in Advance
pharao
Re: Aquastream XT Ultra
Monday, February 25th 2008, 1:24pm
1) don't know, i have no Aquastream ;)
2) no, usually not. not with your "normal" Firmware. AC has a Freeware-version without limitations and with that you can (physically) damage the pump if you set the frequency too high. so don't worry.
gr3if
Monday, February 25th 2008, 4:11pm
You can set the frequency manually to 58heart no problem at all.
johnolg
Monday, February 25th 2008, 5:58pm
Another question is why does the pump run so badly with Automatic Frequency Settings?
gr3if
Tuesday, February 26th 2008, 12:37pm
Real Aw? No one can tell you the real reason. Even Ac is sometimes struggeling.
Tuesday, February 26th 2008, 7:32pm
You can setup any frequency, it will never damage the pump.
The pump is running most silent at 58-61 Hz. You can easily find this out if you have a look at the Current Graph in the Software. The pump will take the lowest current in this range so it runs in the smoothest way.
