• 27.11.2026, 20:22
etoel
Tight fit on SB on Asus Maximus Formula
Tuesday, March 18th 2008, 4:30pm
I have a twinplex XT di-Design (24152) on the SB on my Asus Maximus Formula and it's a very tight fit as you can see from the picture.
Did I pick the wrong block?
Can I just take off a mm from the edge g the bottom part? I don't like that it's touching the capacitors.
typfred
Re: Tight fit on SB on Asus Maximus Formula
Friday, April 4th 2008, 2:31am
Hi!
Have u try to cut a small edge of the screw head? I use plastic screws on my board and had cutted the head a little bit. Therefore the screws are going more straight in the holes and the function is the same. I hope I could help.
etoel
Friday, April 4th 2008, 12:02pm
Quoted from "typfred"
Hi!
I'll look into that - thanks. Trying to rotate it slightly too.
