• 12.10.2026, 07:35
edboswell
Inaccurate temps?
Thursday, March 27th 2008, 3:07pm
Hi, next week I will begin my rant over my aquaero (with a video showing the amount of problems I have with this software/hardware). But today I have a 'smaller' problem, my loop goes like this:
Res-> pump (xt ultra) -> cpu ram etc -> water temp sensor -> rad -> res
Now the pump displays the temp of the water if I'm not mistaken? In which it states it being 25,9 degrees C. The water temp sensor that I put in 'manually' (aqua computer parts), states the water temp is 22,9 degrees C.
Now the water temp should be lower past the pump not the other way round?
Or have I got it completely wrong and that temp is of the actual pump electronics?....in which case you should really write the description of this pump again as its quite misleading (namely the temperature and flow sensor 'functions').
etoel
Re: Inaccurate temps?
Friday, March 28th 2008, 12:52am
I asked the same question 10 posts down - also have a 3c diff. No answers yet...
edboswell
Friday, March 28th 2008, 1:58am
maybe they will like me more and answer it ;) ;) hehe
etoel
Friday, March 28th 2008, 10:14am
Quoted from "boswell"
They'll think you'll bring the angels ;-)
edboswell
Wednesday, April 2nd 2008, 6:30pm
Seriously it's not too hard to say: this is a known problem, or something along these lines.
typfred
Friday, April 4th 2008, 2:42am
Hi!
Maybe the temprature sensor in the pump sit near by the motor. The motor produces secondary temperature too and u have this 3 degrees C more on the display.
Maybe ur secondary sensor is not directly in contact with metal/liquid to garant a resistance free transfer of the heat.
I hope my english was good enough to understand what I mean....I´m german :o)
edboswell
Saturday, April 5th 2008, 10:46pm
Or maybe the pump gets hot therefore it actually heats up the water by 3 degrees :-[
BlackBird
Sunday, April 6th 2008, 1:34am
I don't think that water that is moving with that normal speed the xt ultra produces, could have an temperatur diffrent of 3°C. :)
I think that it's:
1. sensor inexactness: We dont have any high end labor sensors ;)
2. normal diffrent becaus the pump-sensor is heatn up a little bit more becaus of the engine, and not cool down by the water as fast as the engine it heats it up.
egawrangler
Tuesday, April 8th 2008, 12:39am
Pumps add heat. That's a general (and I'm not trying to be a smartass) rule of watercooling.
It is usually best to put the pump directly BEFORE the radiator in a cooling loop, and push the maximal amount of heat out of the rad.
The temp sensor for the pump is indeed outside the water flow (there is no thermal probe in direct contact with the water). This has the advantage of getting you a "close enough" water temp, while providing a more accurate temp of the pump internals (to gauge whether you've cranked the freq up too high).
Why put no probe in contact with the water inside the pump? Because these Aquastream XT's are based on Eheim pumps. Putting a conductive thermal probe inside the pump housing can drastically screw up the electric motor (magnetic stator) that spins the pump impeller assembly. Additionally, AC would have to "re-invent" the wheel of the Eheim pumps. Why fix it if it ain't broke?
This issue pissed me off too, but considering that XT's can be applied to older pumps, the additional control improvements, and Aquaero/Aquasuite integration, the tradeoff is worth it.
edboswell
Tuesday, April 8th 2008, 2:03am
OK thanks for your feedback egawrangler
