• 01.09.2026, 14:06
WoodSpoon
Aquaero Set clock
Thursday, April 17th 2008, 4:26pm
Is it just me or does the aquaero/aquasuite set clock software not work?
I click on it and it doesnt do anything! and everytime I restart my PC the clock on my aquaero has reset.
It only does this when the USB lead isnt connected.
anyone have any ideas?
Re: Aquaero Set clock
Friday, April 18th 2008, 5:21pm
Quoted from "WoodSpoon"
That's the problem ;)
The aquaero must be connected to USB. Otherwise the software can not set the clock on your aquaero.
WoodSpoon
Friday, April 18th 2008, 8:11pm
So even when I set the clock manually using the buttons on the front of the Aquaero it will have to be set againevery time I re start my PC? ???
Is there no way to get it to remember the time without having the usb lead constantly plugged in?
Saturday, April 19th 2008, 3:07am
The aquaero has no battery, so it can't save the time settings.
You can get the ATX break adapter which also has a longer standby wire which can be connected to the aquaero. In this case it will remeber the time etc.
WoodSpoon
Saturday, April 19th 2008, 5:20am
Ok Thanks for the help.
It's not really what I wanted to hear :( but at least it's not a problem with the aquaero.
any idea if a small button battery could be connected to aquaero via the standby wire connectors instead of using the full atx break adapter?
Saturday, April 19th 2008, 4:33pm
The aquaero needs 5 V and ~50 mA in standby. I don't know a button cell with 5 V and even if it exists, it would be empty within a few hours.
WoodSpoon
Saturday, April 19th 2008, 6:11pm
Ok,
Thanks very much for the info.
Those currents will be handy to know :)
THnks for the help
