• 30.09.2026, 23:57
maN1C
multiswitch USB 1.41 Version LT
Sunday, August 17th 2008, 9:57pm
How much load will this put on the CPU?
UpInSmoke
Re: multiswitch USB 1.41 Version LT
Tuesday, August 19th 2008, 2:45am
Strange question. ???
I am thinking none.
The multiswitch works stand alone. The only thing you need to do is program it thru USB with included software.
While you're programming it you might experience some load on your CPU ;D ;D
maN1C
Tuesday, August 19th 2008, 5:23am
Aquasuite is running in your system tray, so it has to use some resources. I want to know how much.
I also want to know from what sensors do the temperaure readings come from, if you use the multiswitch to controll fans by temperature. Can Aquasuite read the temp sensors on your gfx cards or chipsets for instance?
MUFFDIVER
Tuesday, August 19th 2008, 7:11pm
Quoted from "maN1C"
I imagine that it would be a very low usage on system resources but i dont have one and thus cant give you the reading that you want.
Maybe someone here who has one could Ctrl + Alt + Delete and go to taskmanager and check for maN1C Please.
Cheers
maN1C
Wednesday, August 20th 2008, 3:48pm
Looks like you have to do it, muffdiver. 8)
I'd appreciate it if you also could help me find the "any-key" ;D
Jokes aside, i didnt know taskmanager displays application spesific CPU usage relative to full load. For instance, right now there is a prosess running that uses 97. It doesnt say 97 what and total CPU usage is 4%. Bit off topic this though :-)
Back to topic, I'm hoping the Aquaero with its cpu will take most of the prosessing load, so I ordered both... :P
MUFFDIVER
Wednesday, August 20th 2008, 8:51pm
Its what i do buddy. When in doubt or lack of replys on here i just order them anyway.
Then again i normally wait around 10 mins with hitting F5 to refresh before i order mine. ;D
Sorry i couldnt be of any more help. Hope its to your liking when they arive. ;)
