• 22.11.2026, 17:36
vincent.brussels@g
any way to cool a Asus MB?
Wednesday, November 5th 2008, 6:21pm
I have an airplex evo 1080, its an overkill for my system =]
And I have low CPU/GPU temp (all aquacomputer components), however, I have an asus MB, the M3A32-MVP with heat-pipe for RAM together with 2 GPU. And right now the MB is the hottest component in my system (almost 10°C higher than the CPU!).
A simple google search will give you images like this one:
http://www.thg.ru/cpu/amd_phenom/images/…s_2d_resize.jpg
http://www.thg.ru/cpu/amd_phenom/images/board_asus_3d_resize.jpg
I wonder if there is any aquacomputer waterblock to cool it down. If only I can attach some waterblock to the heatpipes next to the I/O (next to the fins on the upper-right corner of the first pic in the previous link) it would be perfect. Or even replacing the heatpipes with WC...
Thanks in advance for your comments.
Vincent
drbo
Re: any way to cool a Asus MB?
Thursday, November 6th 2008, 12:51am
Forget the heatpipe.
look in the shop ...
You need one of these for the mosfet
http://www.aqua-computer-systeme.de/shop…4c62b99d30809a1 (please confirm this with AC)
and two of these for nb and sb:
and of course nipples ...
drbo  8)
WS: W10 | Asus Rog Strix X299 | i7-7820X | Asus Rog Strix 1080Ti | Dominator 32GB | Corsair 860AXi | 512GB Samsung EVO 970 |WC: EK-Waterblocks | AC- Monitor and Control | 3x EK-CoolStream PE 480 | LD PC-V8
Gamer:W10 | Asus R4E | i7 3930K | 3x Asus HD 7970 CF | Dominator 16GB| Corsair 1200AXi | 2x120GB I520 Raid0 | WC: EK-Waterblocks | AC- Monitor and Control | 4x Airplex PRO 360 | MM Extended Ascension
