• 21.10.2026, 07:12
DigitalDevil
Boardupdate!!
Monday, March 25th 2002, 10:33pm
So, schon wieder, aber nun richtig das YaBB SP1.1 ist raus also liebes AC team uppen und das ihr euch über weniger traffic freut!
"Die Änderungen:
New javascript in image tags vulnerability fixed - Michael Prager
Text 188 of english.lng removed - Bjoern Berg
Text 93 of english.lng fixed - Bjoern Berg
Miscoded input box fixed - KIDiddles
Blank board after deleting a board removed - Bjoern Berg
Flood protection IP variable fixed so it works - GreLI[S2]
Version 2.02 of fader.js - NRg
Day wraparound bug in time calculations (that affected clicklog) fixed - BHRA Webmaster
Time check on clicklog typo fixed - Bjoern Berg
Long Image Tag URL's do not wrap now - Corey Chapman
Copyright/Comment URL's and dates updated - Corey Chapman
Menu separator added to admin links on posts for text menu - Corey Chapman
HTML header added to printpage.pl so it works properly - Archon
/ me now highlights the whole line and adds the proper actioner's name - Corey Chapman, Michael Rodriguez-Torrent
Hardcoded "on" removed from sendtopic.pl - Corey Chapman
Quotes in maintenance text no longer causes a 500 - Bjoern Berg
Various HTML fixes to messageindex.pl, search.pl and display.pl - dOCda S, Bjoern Berg
Manageboards.pl reorder bug fixed - dOCda S
Tim Ceuppens' name fixed in admin center - Corey Chapman
Reminder function is allowed when guest access is off - Bjoern Berg
Extra blank lines inside news box of "edit news" removed - Corey Chapman
Members removed from moderator lists if they are deleted (security fix) - Bjoern Berg
Marking a board read directs to the BoardIndex instead of the same MessageIndex now - Bjoern Berg
Shared login now contains 'Forgot password?' link. - Bjoern Berg.
[ and ] in templates now show up in "edit template" textarea. - Bjoern Berg
Main search screen had DHTML compatibility for some sites so ID's were removed - Corey Chapman
Version info updated - Corey Chapman
HTML fix to password reminder box - Corey Chapman, Samm
Flood control disabled for administrators - rehlbe
Show all in the memberlist is sorted as Aa-Zz instead of A-Z a-z now - Uwe Wiedemann
Default menu separator in the language file changed to a | with font tags - Corey Chapman, Auroris
Simpler default template to make NS happy - Corey Chapman"
Quelle yabbforum.com
Al_Borland
Re: Boardupdate!!
Tuesday, March 26th 2002, 12:46am
is das yabb se? so im xp-style? schaut kewl aus. 8)
Gruß, Micha.
DigitalDevil
Re: Boardupdate!!
Tuesday, March 26th 2002, 9:17am
Quoted from "Al_Borland"
www.delekhan.d2g.com/forum
das ist das neue ohne jegliche änderungen
Dino
Re: Boardupdate!!
Tuesday, March 26th 2002, 11:01am
hi
wir werden das forum nicht ohne treffenden grund updaten/ändern. dazu ist das ganze zu kompliziert und zu aufwändig. ich werde mal die liste der behobenenn bugs durchgehen. danke dafür.
wir werden aber immer versuchen ein möglichst "schlankes" forum zu behalten, ohne viel mods und "firlefanz" ;)
dino
DigitalDevil
Re: Boardupdate!!
Tuesday, March 26th 2002, 11:05am
wollt euch ja nur informieren, ;D wie ich es beim letzten mal gemacht habe...
noch was, achtet das die clicklog bzw. acceslog nicht zu groß wird!!! sonnst wird das board grottenlahm!!!
DigitalDevil
Re: Boardupdate!!
Tuesday, March 26th 2002, 11:18am
Quoted from "Fragman"
dieses forum ist schnell, ausreichend und rundum gut *schleim*
greetings to d-no ;) und den rest der ganzen bande hier
nunja, vileciht lässt sich ja noch was rauskitzeln, kenne den fehler... es wird lahmer und lahmer... aber schleichend so das man es kaum merkt... ;D
