• 22.11.2026, 08:50
gezzas525
1/2 inch fittings on AIRPLEX/AQUA TUBE
Friday, June 13th 2003, 4:13pm
Hallo, Iam Englisch so iam mit Übersetzer für diesen Pfosten. Ich werde den das 360 airplex evo Heizkörper zusammen mit dem aquatube kaufen, gleichwohl ich der 1-/2zoll Od Schläuche benutzen wünsche, folglich, das ich 1-/2zollbefestigungen benötige. ich in der Lage, die enthaltenen Befestigungen zu entfernen und schnell anzubringen schließen Sie Befestigungen wie das FESTO, was ist der Gewindedurchmesser der Befestigungen auf dem HEIZKÖRPER UND dem RESERVIOUR?? an? Etwas mögen dieses http://catalog.festo.com/asp/suche.asp?s…bs&ID=239&L=001
pharao
Re: 1/2 inch fittings on AIRPLEX/AQUA TUBE
Friday, June 13th 2003, 4:19pm
hi, welcome
write in english, that's way more easy to understand than machine-translated german... most people here speak enough english to help you...  ;)
gezzas525
Friday, June 13th 2003, 4:28pm
hi, OK I will be using 1/2 inch tubing and want to use quick connect fittings. The festo fittings are quite good however for 1/2 inch tubing they only have 3/8 inch and 1/2 inch connecting screw thread. Will it be possible to fit these onto the airplex and aqua tube. What size threads do they have?
KLEOS
gezzas525
Friday, June 13th 2003, 4:32pm
I see they can fit 10mm BARBS probably the connecting thread is 3/8 inch?
Help will be much appreciated
KLEOS
Ancalagon
Friday, June 13th 2003, 5:03pm
Hi and welcome to the forum!
Bad news: The Airplex has 1/4" threads and the Aquatube has 1/8" threads. But maybe you can find some adaptors somewhere...
-- Hoban Washburn
gezzas525
Friday, June 13th 2003, 8:49pm
How can the threads be different, you have the option of using the same connectors??? so your saying that the 10mm barbs for the radiator are different from the 10mm for the aquatube?
Looks like iam stuck, I was planing to use the dangerden water blocks for the CPU, CHIPSET and GRAPHICS CARD replacing all the fittings with 1/2 QUICK CONNECT fittings.
The best solution would be to make the threads bigger?
the default tubing for all the stuff is too small for good performance?
Why doesnt aqua computer use bigger fittings?
KLEOS
