• 08.11.2026, 11:00
gerald
help with UV light kit
Tuesday, July 29th 2003, 12:34am
hi I'm in the states, i ordered the UV light kit on accident, and now i have to put it together my self, but i have no idea where everything goes, it comes with a trasistor, does anyone have a guide? or can someone help me?
cosmic7110
Re: help with UV light kit
Tuesday, July 29th 2003, 1:25am
:o ::) ??? :P :-[
sry habs net so mit english
//edit soviel wie ich jetzt verstanden hab haste das UV light kit und es is kaputt und du weist wasde damit machen sollt oda ?? ;D
TrOuble
Tuesday, July 29th 2003, 1:40am
Do I understand you right? You dont know how to put the cables together? (sry for my bad english)
hope the picture can help you ...
kaZuo
Tuesday, July 29th 2003, 1:44am
I think he means the uv kit for the aquatube which he has to solder together.
TrOuble
Tuesday, July 29th 2003, 1:47am
Quoted from "kaZuo"
und wieso hilfste ihm dann net?
Did you mean the uc kit for the aquatube?
(this one : )
gerald
Tuesday, July 29th 2003, 2:09am
yes i do not know how to wire that.. can someone show me a close up image or tell me where the stuff goes.. thanks!
TrOuble
Tuesday, July 29th 2003, 2:53am
yes i can ... its not too dificult ...
Sry but i m not able to to tell you how to wire it together (because of my bad english ...)
Martin666
Tuesday, July 29th 2003, 3:24am
Ok you have the Molex-Plug and the Metalpins. Now "crimp" 2 of these Metalpins on one end of this Cable. On the other End connect the red cable with the resistor and the longer pin from the LED. The connect the LED's shorter Pin with the black Cable. Now put the Metalpins in the MolexPlug. Red cable to Yellow Cable from Power supply. And Black Cable to Ground (Black).
If it doesn't Glow, change the polarity from the LED... (I'm actually not sure about the shorter and longer Pin of the LED)
And dont forget the shrinking "tubes". Use them for Isolation...
TrOuble
Tuesday, July 29th 2003, 3:40am
thx Wudelschnitz ... hätt ich auch gern erklärt aber mein englisch reicht dafür net aus :'(
Martin666
Tuesday, July 29th 2003, 3:56am
Glaub mir ich hab mir das auch ausn Fingern gesaugt...
Wenn ich nur wüsste was löten auf english heisst...
Und hoffentlich fragt er nochmal hier, bevor er nen kurzen auslöst....
gerald
Tuesday, July 29th 2003, 4:09am
thanks alot guys...i will try that!
Tahigwa
Tuesday, July 29th 2003, 4:41am
Quoted from "Wudelschnitz"
"löten" übersetzt man mit "solder" :)
Ich benutze zur schnellen Übersetzung Babylon, einfach auf das zu übersetzenden Wort klicken, dann erscheint die Übersetzung. www.babylon.com
Tahigwa
Quoted
A64 NC3500+ 939 zu verkau
gerald
Tuesday, July 29th 2003, 7:48am
Dank für die Hilfe jeder
traurig ist mein Deutsch schlecht :-[
TrOuble
Tuesday, July 29th 2003, 4:22pm
Quoted from "gerald"
Unser englisch aber auch ;D
