• 04.11.2026, 11:44
Nightreaver
Question regarding Evo capacity
Monday, August 11th 2003, 1:17am
Sorry I'm writing in english, but my german is really crappy (I'm a Dane).
My question is regarding the capacity of the different Evo radiators. The setup I'm interessed in constructing is:
-Cooling my MB, GeForce4 and CPU
-Cooling my HD's using 5 x Aqua Drives
My question is then how i should construct the system? Is one 12V pump enough? Do i need 2 separate systems? If using one system should I use Evo 360 or is 240 enough?
I'd be really glad to hear from some of you hardcore water-nerds :)
Best regards,
Lau
pharao
Re: Question regarding Evo capacity
Monday, August 11th 2003, 1:21am
Hi and welcome to the forum! :)
one Pump is enough.
are you planning to use actve cooling (fans) or not? if yes, the 240 is enough, if not, I'd use the evo 360 (since HDDs like it a little cooler)
Nightreaver
Monday, August 11th 2003, 1:30am
Thx for the warm welcome and for the very fast answer!
If it's posible for the system to keep cool enough without fans I would be very impressed, very! So what you are saying is that if I install the system with an Evo 360 (in the top of my case) I can keep 5 HD's + CPU/MB/GF cool with no fans?! Wow!
Chrizzz
Monday, August 11th 2003, 1:32am
w0w... 5 Aquadrives ;)
Well, it only makes sense to do active cooling on that, so your choice should be the Evo240 with 2 Fans (Papst is pretty noiseless).
Taking an Evo360 instead only gives you about 2°C better temps (when active cooling).
€: Now reading your 2nd post...
It doesnt make sense to cool everything WITHOUT fans. It would work, but your harddrives would get temps ~50°C, and thats to high. Furthermore, you HAVE TO set up the radiator SEPERATLY (basicly not in your case). It has to stand clearly.
Signatur out of date...
pharao
Monday, August 11th 2003, 1:34am
no, only when the evo is external
internal installation blocks the air from circulating too much... but if you use "Papst" fans @ 5 or 7 Volts, they are not hearable...
Nightreaver
Monday, August 11th 2003, 1:40am
Right, as I understand it my needs are:
-1 x pump
-1 x Evo 240 (internaly mounted with 2 Papst coolers)
-1 x Aqua Tube
-5 x Aqua Driver
-cooling heads for the rest of the system + hoses osv.
And this sould keep my system cool and most importantly _QUIET_?
Thx for alle the help so far!
pharao
Monday, August 11th 2003, 1:44am
right. I'd recommend you to buy, a "Set", you can save some money there.
before you send your order, post it again here so we can take a last look & check.
Nightreaver
Monday, August 11th 2003, 1:50am
Sounds great!
The problem with sets is that there aren't any with the new 12V pump, which I've really been drulling at :)~~~
I'm saving the money for it at the moment, but I'll thow a message when I'm ready to go.
Again, thx alot for the help. This is really a great forum!
pharao
Monday, August 11th 2003, 1:55am
The 12V Pump will only be available from August, 17th .
There will be new Sets containing the Aquastream (the 12V Pump), then
Nightreaver
Monday, August 11th 2003, 2:02am
Okay, thx.
pharao
Monday, August 11th 2003, 2:03am
It's a pleasure :)
MojoMC
Monday, August 11th 2003, 2:19am
Quoted from "Nightreaver"
If you really want to cool 5! hdd's, I would suggest 2 seperate Systems (Evo 120 for hdd's). Perhaps its not necessary, but it reduces the risk of heating your hdd's by CPU & GPU.
Willkommen in Bruchtal, Mr. Anderson.
Nightreaver
Monday, August 11th 2003, 2:29am
Quoted
Yep, that was also my first impression, but it's a pretty expensive solution. I would do it if I had the money. Just think; my Lian-Li PC70 with 2 AquaTubes in the front.... mmmmmh :)
MojoMC
Monday, August 11th 2003, 2:35am
...but it's a pretty expensive solution....with 2 AquaTubes in the front.... mmmmmh :)
Evo 120 and the normal Eheim 1046 (much cheaper and imho good enough) doesn't make the amount so high. It's the 5 Aqua-drives, thats the really expensive part of your whole project!
You don't have to use Aquatube, AC has some other "Ausgleichsbehälter", e.g. the aquainject.
Nightreaver
Monday, August 11th 2003, 2:44am
Quoted from "MojoMC"
Yep, your absolutely right. Then an extra question; is it easy/possible to hook up the Eheim 1046 to the PSU? And don't they uses quite a bit more power (I've got 480Watt to spend).
Mmh, but the AquaTubes are really nice and match my case very well.
Btw, thx for your thoughs.
Nightreaver
Monday, August 11th 2003, 2:48am
Btw, how's the connectivity regarding SATA and the AquaDrives? As fare as I can see, they are built for std IDE.
MojoMC
Monday, August 11th 2003, 3:45am
...is it easy/possible to hook up the Eheim 1046 to the PSU? And don't they uses quite a bit more power (I've got 480Watt to spend)...
The standard 230V Eheim 1046 and the "aquastream" are not really different. Its just the voltage they are working with and the (attention, my opinion: more or less usefull) gimmicks of the aquastream
The Standard Eheim 1046 works with 230 Volts so you just have to get the plug out of the case or 230V into the case- imho no problem. I use several sockets outside of the case connected with one switch for PC, Monitor, printer and Eheim ("Steckdosenleiste"). No problem to fill the system. The pump needs about 5 watt.
The "aquastream" uses power from your PSU - but don't care about this 5 watts (similar to standard 1046)...
Now, look at the price. I (not everyone, just I) don't need the gimmicks and I don't care about the "easy-to-install"-12V, that means I would never spend the double amount of money.
Now you have to decide on your own...
ThaDog
Monday, August 11th 2003, 4:29am
Yeah.
Listen to MojoMC......... he is absolutly right about that point.....
The Aquastream is indeed a very nice toy, but there are some things you have to think about....
1. More electronics could mean more problems ( it could, like the 12V Eheim did from another company )
2. It isn't so easy filling up your Watercooled system, even if they put 1000 special "plugs" for the PSU in the package
3. The Eheim 230V is tested for over a long time now and is absolutly reliable.... The 12V hasn't yet been tested that long, so time will tell us if it is equal to the 230 V pump.
4. I can buy 2 Eheim 1046 for the money you spend on the 12V version..........
There are ofcourse also some advantages when you buy the Eheim 12V
1. You get the first Pump, specialy designed for Watercooled PC systems
2. You get the first "real" 12V Pump
3. It looks fancy too
4. It has also some nice "must have" gimmicks on it...
If you want it or not is your choice..........
It's definitly worth the money, but there are some cheaper solutions ( 230V ) that have proven to be very good.....
yours,
ThaDog
Chrizzz
Monday, August 11th 2003, 11:56am
Dont do that! There is absolutely no reason for "creating" 2 Systems. HDDs are producing heat at around 5-10W. This is nothing. Just make one system an save some money at this part ;)
The Evo240 will be enough and it will give you good (and quiet) temps, thats for sure!
kampfsau
Monday, August 11th 2003, 12:13pm
well, i don´t really see the reason to cool HDDs with water (or at all) anyway ::)
using maybe 1 80mm-Fan (for instance a silen Papst) would be effective enough and still be a quiet solution
well unless you like to use the aquadrives as a silencing device that is... cause as soon as the loud CPU/GPU/NB-fans are gone, you´ll notice how much noise a HDD can produce ;)
speaking of noise: your PSU is probably another source! you should think about modding it with one large 120mm-fan at 7 or 5 volt or (since you appear to be quite wealthy... 5 aquadrives... pfuuh 8) ) buy a watercooled PSU like the aquapower (which has a 230V-plug included) or the coolcurrent. both can be found in ACs shop :)
