• 04.09.2026, 08:28
GuPPie
To warm CPU?
Thursday, August 14th 2003, 12:35am
Today I installed my Aqua computer kit, I have an Evo 120, A normal Cuplex cpu cooler and The hydor L20.
The water flows on this way: Hydor - Cuplex - evo 120 - Aquatube- hyfor.
Now my CPU temp is 48 C idle en 53 full load.
That's kinda high isn't it?
If you need more info to answer my question, feel free to ask :)
And when writing an english answer is to hard for you, try German ;D
GuPPie ( Niederländer )
Steppenwolf
Re: To warm CPU?
Thursday, August 14th 2003, 12:36am
what processor do you need?
How hot is the air in your room?
Sry for my bad english.
so long sTeppe
XP1700+@210*10,5->Cuplex|| 512 MB GeIL PC - 3200 + 512 MB Corsair PC - 2700|| Rad.9800Pro@434/376->WK-CU C2 || Asus A7N8X Deluxe ->NB@Twinplex|| 160GB Samsung + 80GB IBM extern|| 550W NT R.I.P.|wakü|| Evo120 +Papst@5-7V +Evo360 extern||
GuPPie
Re: To warm CPU?
Thursday, August 14th 2003, 12:38am
I have an T-bred 2400+ Room temp I dont know :S but my case tem is ( wich is open ) : 35 C
Hayes
Re: To warm CPU?
Thursday, August 14th 2003, 12:40am
Your CPU Temp is great!
Trust me!
Peace - Love - Linux
Steppenwolf
Re: To warm CPU?
Thursday, August 14th 2003, 12:41am
yes then your temperatur is a bit high. Have you the "3Nasenhalterung" oder the "4-Lochhalterung?? Have you used Thermal Greese? If yes look if its too much or to less.
so long sTeppe
GuPPie
Re: To warm CPU?
Thursday, August 14th 2003, 12:46am
I used AS 3 I will check now how much there is on it :)
Can I lay down my case with everything in it?
I have the 3 nase halterung ( oder so ) :)
oh and ehm I have a little over clock: 14x150 :P to small to increase temp :)
2000@2100 :P
Vcore is still the same
Steppenwolf
Re: To warm CPU?
Thursday, August 14th 2003, 12:48am
yes normally is this possible. ;)
Another question have you an fan on the radiator if yes what type and with wich voltage?
so long sTeppe
GuPPie
Re: To warm CPU?
Thursday, August 14th 2003, 12:50am
A Papst ( low noice ) at 12 V It doesn't blow but it sucks :P as you know what I mean :P
See you in a minit, gonna check AS 3 :)
Steppenwolf
Re: To warm CPU?
Thursday, August 14th 2003, 12:52am
yes then your temperatur is really a bit high.
I have
Pump-"Spannungswandler"-CPU-NB-PSU-Evo120-AB
and 50°C on the processor and 40-42°C in the case my Papst is also sucking.
so long sTeppe
GuPPie
Re: To warm CPU?
Thursday, August 14th 2003, 1:03am
Hmm. ok I removed a bit of AS 3 , wasn;t much on it biut just to try, At the momentn mijn temp is 45 C Stabel, I will check again after a few mins
Brain
Re: To warm CPU?
Thursday, August 14th 2003, 1:07am
Which mobo do you have?
Steppenwolf
Re: To warm CPU?
Thursday, August 14th 2003, 1:08am
45°C is ok i think.
GuPPie
Re: To warm CPU?
Thursday, August 14th 2003, 1:12am
temp is 47 again, water seems to warm up fast  ( till 48 C )
I have an Albatron Kt400 ( Maby a lousy temp sensor?)
GuPPie
Re: To warm CPU?
Thursday, August 14th 2003, 1:19am
Oh and everything is with case open, so.....
Hoebbel
Re: To warm CPU?
Thursday, August 14th 2003, 1:27am
ahh een nederlander :)
ik spreek een beetje nederlandse, maar niet zo goed ;)
Kun jij me zeggen waar de radiator is?
Groetjes Kai
GuPPie
Re: To warm CPU?
Thursday, August 14th 2003, 1:52am
I the front of the case... on the floor,with 1 outtake fan sucking
Damn, case temp rises to 40 Degrees :S
GuPPie
Re: To warm CPU?
Thursday, August 14th 2003, 1:55am
I can set a picture online, of someone can tell me how, and has some space on the net
ThaDog
Re: To warm CPU?
Thursday, August 14th 2003, 1:59am
Ik kan nog een beetje meer nederlands, hehe.
Ok, ik denk dat je Temps heel erg in orde zijn.
Wat ik wel graag zou willen weten is je water temp en je kamer temp.
Dat kan je goed nameten met een koortsthermometer........ vooral omdat je een AquaTube hebt.
Wat ook heel veel helpt is een kleine 80 mm Fan op je "spannungswandler" te laten blazen. ( geen idee hoe je "spannungwandler" vertalen kan........ ik ben al te lang weg uit Nederland........ gotver......... ).
Daardoor gaat je CPU temp met een paar graden naar beneden.
Dit komt doordat je "spannungswandler" de Temp sensor van je Motherboard verhitten........ begrijp je wat ik bedoel ?
groetjes,
ThaDog
ps. Hup NAC. hehe  ;)
GuPPie
Re: To warm CPU?
Thursday, August 14th 2003, 2:16am
Thermometer slaat over de 42 graden heen bij meten van water temp :P
The water temp is over 42 degrees!!!!
in 1 sconde it goves 41.7 and the it crashes :P
454-bigblock
Re: To warm CPU?
Thursday, August 14th 2003, 2:43am
Maybe the problem is the high room-temperature.
If you are living "under the roof", it is no surprise if your room-temperature is 40 degrees or more.
48°C idle is ok, if the Nederlande has such high temperatures as Germany these days.
are there reasons why you worry about the temperature?
I don´t think anybody with a regular air-cooler has better temperatures these days.
