• 07.11.2026, 18:06
GuPPie
Re: To warm CPU?
Thursday, August 14th 2003, 3:22am
I expected low 40, but when I start thinking about it. I realised my temp was 60 degrees before. at same noice level. now it is 49. I turned mij papst so now its blowing @ 7 volt and 2 outtakes behind. My temp is instead of 56!! ( with case closed and papst sucking) 49 so I won 7 degrees ( case closed and papst blwoing). And yes I'm below the roof :)
Ratman
Re: To warm CPU?
Thursday, August 14th 2003, 11:06am
Don´t worry about your temps, they´re all fine :)
I use almost the same parts in my watercool-system and my temps are nearly the same. But that´s OK because of the high temps this summer. If the temps stay at 60°C or below, there´s no need to worry about it, trust me.
-=Ratman=-
GuPPie
Re: To warm CPU?
Friday, August 15th 2003, 1:35pm
Hmm, my water seems to warm up quickly, my temps started at 35 degrees, and then slowly it rises to 52 ( At the moment ) My v-core is 1.95v and I'm running 2500 MHZ With my XP 2400+. How can I get my water temp down?
JimKnopf
Re: To warm CPU?
Friday, August 15th 2003, 3:48pm
The normal VCore is about 1.7V if you have 1.95, it is not a quetion why the CPU is so hot.
You may try a lower Voltage
Gruz
Jim
p.s.: sorry for bad english :)
Es gibt zwei arten von Dingen, solche die kaputt sind und repariert werden müssen und solche mit denen man Spielen kann bis sie Kaputt sind und repariert werden müssen
MojoMC
Re: To warm CPU?
Friday, August 15th 2003, 4:19pm
Quoted from "GuPPie"
Now my CPU temp is 48 C idle en 53 full load.
That's kinda high isn't it?
You can't count on the temperature measured by the mobo. I installed an new one. Temps @ old mobo: 39° load. Temps @ new mobo: 49° load.
The only interesting is the water temperature. I need an thermometer...
Willkommen in Bruchtal, Mr. Anderson.
Pruneau
Re: To warm CPU?
Friday, August 15th 2003, 8:55pm
Yes you really need a separate sensor. Mobo sensors aren't very precise, from my very limited experience.
GuPPie
Re: To warm CPU?
Friday, August 15th 2003, 10:54pm
I made some changes, I build a 5 cm long fanduct, wich is much more quiet. :D:D. I put my v-core @ 1.65 again, And mu idle temp now is 43C witch papst @ 12v and 2 outake fans @ 12v. I will upload my water temp in a minit..
