• 28.09.2026, 05:46
kayaker
AMD Athlon64
Thursday, September 25th 2003, 5:09pm
Hi all!
When will be available a retention system to use Cuplex Evo in Socket 754 for AMD Athlon64 ?
thanks
kampfsau
Re: AMD Athlon64
Thursday, September 25th 2003, 5:18pm
aquacomputer said, they´re already working on it, release should be soon :)
but the question should rather be:
when will there be athlon 64 chips in abundant quantities and an affordable prics? :P
Metallurge
Re: AMD Athlon64
klick
retention system is under construction, not yet available.
kayaker
Re: AMD Athlon64
Thursday, September 25th 2003, 5:22pm
You can see my system  ;D :
Asing
Re: AMD Athlon64
Hoffentlich gibt alle dinge schnell ;D
Ich brauche ein AMD Athlon64 und eine complete wakü set, mit Aquaero. Also, als AE-team 600 Euro brauchen wissen sie wass zu tun.
Asing
Aircooled AMD Athlon 550, 256MB RAM, 80GB HDU, GeForce 256. Next system : AMD Athlon64 3200+, 512MB RAM, GeForce 5600FX and watercooled by Aqua Computer
Asing
Re: AMD Athlon64
Thursday, September 25th 2003, 5:29pm
Quoted from "kayaker"
ARRRGH He has one!
want one too.....
I have a question, since you seem to have it complete.
I thougt about the heat dissipation and which radiator to buy. Will the AirPlex 240 be suitable (would love to switch the fans off) or is it too small and do I need an AirPlex 360?
I have been searching for some time, but there are no figures or advices which radiator to use. EG <70W Evo 120, >70W and <100W Evo 240, and extreme cooling power, use the Evo 360.
To make the investment a good one, having plenty of headroom is a good idea. I have no plans yet to implement chipset/VGA cooling/Hard disk cooling, but I might in the future.
Asing
kayaker
Re: AMD Athlon64
Thursday, September 25th 2003, 5:53pm
Asing, I am affraid that this CPU uses almost 100W. So an EVO 240 with quite fans could do the job.
I have tryed the Evo 360 in passive mode but is not suficient for a CPU like this and a Vga like ATI 9800 pro.
kampfsau
Re: AMD Athlon64
Thursday, September 25th 2003, 5:55pm
@Asing: für passivbetrieb (=ohne lüfter) leg dir am besten einen evo360 (oder gleich einen evo1800 ;D ) zu, damit bist du auf der sicheren seite
ein 240er wird für betrieb ohne lüfter zwar reichen... aber gute temps kannst vergessen
Preda
Re: AMD Athlon64
Thursday, September 25th 2003, 5:59pm
Stop, you the CPUs can go up to 100w! they actuel one have around 60w! so the 100 watt is the maximum the core can take!
JE
Re: AMD Athlon64
Thursday, September 25th 2003, 9:32pm
if the 360 is not enough, try it with an 1800.
But.. if you have room-temperatures about 40 grades, even the 1800 is not enough, if in passive mode. with room-temperatures this high, you need at least one fan.
DSEDS
Re: AMD Athlon64
Thursday, September 25th 2003, 10:40pm
Quoted from "JE"
But.. if you have room-temperatures about 40 grades...
Im sure that no one here living on the sun!!  ;)
Asing
Re: AMD Athlon64
Thursday, September 25th 2003, 11:52pm
AMD has told the manufacturers of cooling equipment that the complete Athlon 64/FX range (even with the ones to come) have a maximum of 89Watt dissipation. The current Intel P4 3.2 EE has a dissipation of about 100-110Watt.
Air cooled, the AMD is just 35-39 degrees, at full load it seems to be 45 degrees.
So, the new AMD CPU's have dealt with their hunger for power. Since I also want an Aquaero, I can have my fans temperature controlled. With the Evo 360 it should make a nice cool silent combination.
Does anyone have te,ps from the same system with different radiators?
Asing
