• 17.11.2026, 20:47
Asing
Question for those who have an AquaDrive
Friday, September 26th 2003, 3:03pm
I have a nice question for the next PC to built ;D.
I am the lucky owner of a Compaq 40/80 DLT unit:
According to specs, it produces 28W of heat. In my current case, I left the 5 1/4 bay under the unit open. If I close the gap (or worse, mount a CD-ROM drive), I get tape errors. It justr gets too hot.
Seeing the AquaDrive, I think the top side bars left and right (blue) are cooled as well. If I mount the AquaDrive under the tape unit, some heat will be taken away by the water cooling system.
could anyone tell?
Aircooled AMD Athlon 550, 256MB RAM, 80GB HDU, GeForce 256. Next system : AMD Athlon64 3200+, 512MB RAM, GeForce 5600FX and watercooled by Aqua Computer
slame
Re: Question for those who have an AquaDrive
Friday, September 26th 2003, 4:04pm
hi ..
you are right. the left and the right blue unit is designed to take away the heat. so if there is no gap to the next unit (cd-rom e.g.) it should take away the heat from it too.
i think it should work
slame
Asing
Friday, September 26th 2003, 4:46pm
computer equipment always sits tight together. CD-ROM is also a good idea. "Watercooled CD-ROM player".
add one to cart!
Chrizzz
Friday, September 26th 2003, 5:19pm
It might work, but there are def. better solutions that will cool better and are less expensive...
Signatur out of date...
