• 04.10.2026, 04:49
jcab
jemand mit externer Airplex Halterung, bitte Picz
Wednesday, October 1st 2003, 2:41am
hi !
suche fotos vom inneren des Gehäuses bei jemanden der eine externe Airplex Evo Halterung hat.
möchte nämlich gerne die Schlauchführung vom Airplex im inneren sehen.
danke im voraus.
curly
Re: jemand mit externer Airplex Halterung, bitte P
Wednesday, October 1st 2003, 2:52am
guckst du außen
guckst du innen
Von unten sind die Gehäusedurchführungen leider nicht erkennbar, wegen Dämmmaterial verdeckt.
jcab
Wednesday, October 1st 2003, 2:55am
danke ;)
mehr fotos ;D
curly
Wednesday, October 1st 2003, 3:07am
nur einige Pics
jcab
Wednesday, October 1st 2003, 3:11am
vozu die Lüftergitter auf den Airplex360, wenn da keine Lüfter drauf sind ?
bräuchte mehr Fotos vom inneren auch von andere user ;)
Stulli
Wednesday, October 1st 2003, 1:28pm
Interessant, der 240 wird vom Netzteillüfter durchgepustet... :)
Asing
Wednesday, October 1st 2003, 2:04pm
Look closely.......
This big unit has an AQUAERO!!!!!!!
:'( :-/ >:( I WANT ONE TOO!
Aircooled AMD Athlon 550, 256MB RAM, 80GB HDU, GeForce 256. Next system : AMD Athlon64 3200+, 512MB RAM, GeForce 5600FX and watercooled by Aqua Computer
Katzenfreund
Wednesday, October 1st 2003, 2:09pm
IT hasn`t it`s an aquabay!
curly
Wednesday, October 1st 2003, 2:22pm
Quoted from "Asing"
Ja, ein Beta-Aquaero! :D
Asing
Wednesday, October 1st 2003, 3:20pm
@Curly:
Can you please post some pics of this beta-aquaero in action? Or screendumps from it's software :)..???? Would be very nice to see what it can do.
Asing
curly
Wednesday, October 1st 2003, 3:31pm
@ Asing
I'm sorry, but I was just joking. The controler is by a competitive producer that isn't talked about in this forum.
jcab
Wednesday, October 1st 2003, 4:00pm
Quoted from "curly"
sind diese Löcher leicht zu bohren ? ::)
Asing
Wednesday, October 1st 2003, 4:09pm
It should be!
The material might be aluminium. First, determine where to drill the holes. Secondly, make a dent in the material with a sharp object like a screwdriver. This is to make sure the drilling equipment doesn't go out to take a walk while drilling. Your hole won't be in the right place.
If you can, support the hole-to-be with a piece of wood. And drill from the outside to the inside.
Asing
Asing
Wednesday, October 1st 2003, 4:12pm
Quoted from "curly"
@ Asing
It looks damn real! I don't know any other manufacturer creating the same items. It has the same 4 buttons, the same rough-but-very-nice finish with the bolts and I thougt I saw the connectors for the 4 pabst fans.
EDIT : the AE has only 3 buttons, the text is on the top left, and the screen is without edges. Clearly, this is something else.
Could you PM a link to me?
jcab
Wednesday, October 1st 2003, 5:58pm
und kann man die externe Halterung zusammen mit einen Airplex Evo 360, auf den Deckel eines Chieftecs Gehäuses bauen ?
denn im folgenden Bild sieht bleibt ja die Halterung richtig an den Grenzen des Gehäuses:
soll ich mir vielleicht denn Airplex Evo 240 mit der externen Halterung hollen, statt den 360 ?
mysterox
Wednesday, October 1st 2003, 6:02pm
also ich habe den 360er mit der externen halterung auf meinem cs601 geht ganz gut steht hinten nur ein kleines Stückchen über!
Mysterox
jcab
Wednesday, October 1st 2003, 6:43pm
Quoted from "mysterox"
Mysterox
und die hintere Halterung ist auch richtig geschraubt ?
wie wärs mit fotos ? ;) ;D
Agent_Master
Wednesday, October 1st 2003, 7:24pm
Also APE360 mit extern Halterung passt meiner Meinung nach nicht so einfach aufs 601. Ich dachte das würde genau hinhauen, doch in wirklichkeit fehlt da ca. 1 cm.
Das Probleme ist, dass die Bohrungen zum befestigen ganz außen der Halterungen sind und somit müsste man vorne die Schrauben in die Plastik Front machen, was natürlich nicht möglich ist. Zuerst hatte ich vor das ganze hinten ein wenig überstehen zu lassen und dann hinten nur leicht zu kleben, doch das sieht ziemlich bescheiden aus. Hab mir nun die Arbeit gemacht und zwei kleine "Stege" ausgesägt und damit die Bohrlöcher von der vorderen Halterung praktisch nach hinten "verlegt".
So habe ich nun hinten die Halterung genau am Ende das Cases und vorne liegt sie auf der Front auf. Ist auf jeden fall die schönste Möglichkeit.
