• 13.10.2026, 04:13
castrol
wasser temp..? :-(
Monday, January 26th 2004, 2:16pm
He ich habe ein Problem. Meine Temperatur ist 38-40 ilde, volle Last 43-46. Ich habe dieses.
Aqua-Computer Twinplex,
ATi Ausgabe Aquacomputer Cuplex evo
Heizkörper des Aqua-Computers
Evo120 Papst 120 Millimeter.
Aquaschlauch revisour
Eheim 1048.
mys System:
Barton 2500@3200. Vcore Abit 1.65 Nf7-s 2*256 Hyperx 3500
Hoffnung können Sie mir helfen...
theBLACKdragon
Re: wasser temp..? :-(
Monday, January 26th 2004, 2:22pm
???und was ist dein Problem? diese TEMP. sind ganz normal!
my system:2xXeon 5420/ Tyan Tempest i5400XT/XFX 8800GTX XXX/ 8GB Kingston ECC RAM/ 1x 150GB WD Raptor/2x Segate Barracuda ES.2 500GB in Raid1
Ancalagon
Monday, January 26th 2004, 2:33pm
Hi and welcome to the forum!
I get the impression german is not your native language so feel free to write english - many people here understand english quite good. ;)
As far as your temperature problem is concerned: Are those water temperatures or CPU-temperatures? If it's the CPU the temperatures aren't bad at all - if it's the water the temp is a little high. How / where do you have mounted the radiator?
-- Hoban Washburn
major23hh
Monday, January 26th 2004, 2:40pm
mmhh, I think the temperatures are really allright, don't panic anyway ;)
castrol
Monday, January 26th 2004, 3:11pm
okay, i am from denmark, and may english is way better than german.
i have mounted the radiator, down in the front of the kabinet.
It is cpu temp.
p.s nice forum you got here :-)
major23hh
Monday, January 26th 2004, 3:27pm
mmh, do you have some pics of it? May be it would help us a little bit!
chu
Monday, January 26th 2004, 5:52pm
Hi and welcome to this forum,
i got nearly the same system and temperatures. seems all ok for me.
nf7-s rev2, lastest bios
2500+@3200+ with old cuplex, 1,725V Vcore
radeon 9800pro (not oced) with twinplex
Hdd with aquadrive
chipset with twinplex
radiator is a 240 airplex evo with 2x papst 120mm@5-7V
cpu: 42 idle, up to 50 in gameload, hdd 35-38...all at 21 degree in my room.
just enjoy your quite and cool running system ;-)
cu
akula
castrol
Monday, January 26th 2004, 11:14pm
Now i got the temp down a little.
barton 2500@2300mhz
Vcore 1.80
Ilde temp 38
Full load 42-43
I took the hole shit out of my kabi, and reinstalled it again :-)
Is that temp okay?
Thanks mates!
major23hh
Tuesday, January 27th 2004, 12:14am
these temps are more than ok with a vcore high like yours! :)
mindheat
Tuesday, January 27th 2004, 2:53am
welcome at the forum
the temperatures are really ok, for better use a ape240 the the temps go down ;D
[CENTER][/CENTER]
castrol
Tuesday, January 27th 2004, 8:30pm
what is ape240? Do you have a link?
Mr._X
Tuesday, January 27th 2004, 8:33pm
Airplex Evo 240
pharao
Tuesday, January 27th 2004, 8:34pm
ape = airplex evo  ;)
edit: typing fast is difficult while eatin' pizza ;)
chu
Tuesday, January 27th 2004, 8:43pm
well...if your system runs fine and you got no crashes you wont get much lower temperature by using the Airplex Evo 240. I would expect 1-2 degrees compared to the Airplex Evo 120. Not more. Its up to you to decide if this is worth the money and the work.
Otherwise the Evo 240 would give you some more ressources for future Systems. ...you can upgrade anytime... ;)
cu
akula out
castrol
Tuesday, January 27th 2004, 8:59pm
Okay thanks a lot...think i will wate for a little time :-)
Another question:
Right now i am using plug And play, but what is the biggest Schlange i can use too my system?
Eheim 1048.
is it 12mm? and if it is, will it fit too my, eheim 1048?
hope you understand my question :-)
major23hh
Tuesday, January 27th 2004, 9:05pm
Thats depending on the connectors you are using. but the additional water that is floating trough a system with bigger sized connectors and bigger sized hose does not reduce your temps (see as addition: www.henrik-reimers.de but thats german ;) )
So dont chance your plug & cool interface, its safe, its big enough, its easy installed, something I may had developed ;)
castrol
Tuesday, January 27th 2004, 11:41pm
Okay thanks mate :-)
Maybe i will buy and evo 240
mindheat
Wednesday, January 28th 2004, 1:21am
no idea to say it in english, so i hope u understand it in germ ::)
u can also
die cpu gerade schleifen da der kleine 1cmx1cm chip meist in der mitte höher ist, so liegt der evo besser auf und kühlt besser
mit haarwinkel kontrollieren ;)
anyone plz translate if castrol dont understand ;D
[CENTER][/CENTER]
jabba
Wednesday, January 28th 2004, 2:03am
Hello Castrol,
Please do not manipulate the cpu ;) Your Problem is the little too hot water... this is absolutely normal by only one ape120! The only way is buy a better radiator for nice cooling :)
best regards
jabba
mindheat
Wednesday, January 28th 2004, 4:26am
omg
@jabba
dont say anything if u dont now it >:(
@castrol
my 3 amd are all "manipulate" and the temps go 2-6° down
by one more, by the other not :P
but is not a easy work and u must be carefuly, nerver forget the cpu not cheap ;D
[CENTER][/CENTER]
