• 22.11.2026, 16:41
EpS
Re: HELP ENGLISH
Monday, January 13th 2003, 1:57pm
Hi Dude,
if Aqua-Computer can't Ship you the stuff you want. Call me... (Instant Message)
You Pay the Shipping-Costs to me and i will order the Stuff for you and send it to you at the normal Way by UPS oder FedEx...
But I think Stefan and his Team will help you anyway.
EpS
P.S.: Sorry for my bad english.
PAB
Re: HELP ENGLISH
Monday, January 13th 2003, 3:05pm
You should also order some 90° and T -connectors:
gerald
Re: HELP ENGLISH
Tuesday, January 14th 2003, 12:05am
ok thanks for the help so here is my new list
1. Cuplex Evo 3-Nasen-Haltrung
2. twinplex nForce™-Chipsätze, Rev. 1.1, Plug & cool gerade, 850/ nforce
3.Festplattenkühler aquadrive, Plug & cool gerade, Blau.
4. airplex evo 240, Plug & cool gerade
5.airplex evo Einbaublende 240
6.Ausgleichsbehälter aquatube, Blau, Plug & cool gewinkelt
7.Edelstahl-Einbaublende für den aquatube
8.Beleuchtungsmodul UV EUR 11.99, für den aquatube
9. Pump Eheim 1046
Other things:
5 metres Schlauch PUR, glasklar
1 pcs acfluid - farbloser Korrosionsschutz
Set 10 x UV-LED 5 mm
GlowMotion Wasserzusatz
90° and T -connectors??? how many i dont know...
thats it! fi you have anything to add please do, now i'm waiting for a resonce from AC... wish me luck :)
PeterBang
Re: HELP ENGLISH
Tuesday, January 14th 2003, 12:34am
Hi there.
i just read your list and there is somethink that could be missunderstood in the product description. Are you shure that you need the Chipset Cooler for an nForce Board? Because when you bougth yourself an nForce2 MoBo like the Asus A7N8X, you'll better go for the standard chipsetcooler (Twinplex rev1.2 chipsatz chipsatz plug&cool gerade) ,because the nforce-Model won't fit.
It is possible to get out with no 90°Connectors at all, but i won't recommend that. I suggest that you take an sheet of paper to plan your "water wiring". That's the most common way to get out the amount of the needed connectors.
You only need one t-connector, which you should install near to the outlet of the Eheim, so you can easily get the water out of the system.
That's what i can tell you.
I hope you can understand my English, for its not the best
Good Luck
The reason I know I am God is because one day as I was praying, I realized I was talking to myself.
gerald
Re: HELP ENGLISH
Tuesday, January 14th 2003, 1:40am
ok i understand kinda, that i should just leave the nforce out... i'm starting to think i should just buy one of the crappy american water cooling setups, and dream of the day when i can get something good..... :(
Chiefmasta
Re: HELP ENGLISH
Tuesday, January 14th 2003, 10:43am
Do you really want one of that boaring usual american watercooling systems?? You should be one of the first persons in the US to get one of those here ;)
About the 90° Connectors, as you can see here or even here you can use them, but you dont need them (i don't use them).
The T-Connector you need to get the water out of your system (i didn't use that either but i wish i had :-/)
PeterBang
Re: HELP ENGLISH
Tuesday, January 14th 2003, 3:28pm
no that's not what i intended to say. You only have to use the nForce chipset cooler if you hava an nForce1 or an Intel MoBo. Just tell us which MoBo you use and we tell you the needed Cooler.
Re: HELP ENGLISH
Tuesday, January 14th 2003, 4:21pm
Send me a mail: Stephan@aqua-computer.de
We will find a way...
gerald
Re: HELP ENGLISH
Wednesday, January 15th 2003, 8:29am
ok before i email stephan, my motherboard is the asus a7n8x, im going to be using amd xp 2600-2800 (haven bought it yet :) ) anything else i need to know before i revise my final list... i want to get it all right once, because im sure its going to cost me a small fortune to have this shipped. thanks!
Henne
Re: HELP ENGLISH
Wednesday, January 15th 2003, 9:34am
You are going to order an Eheim 1046, are you sure it fits to the power-system in the usa??
It's made for 230V, and as far as I know it's just 110V in America; would be to bad if you ordered something you can't use...
Quoted from "Eikman"
Juhu, ich werde mal in einer Signatur zitiert :D
gerald
Re: HELP ENGLISH
Wednesday, January 15th 2003, 10:02am
ok good idea! i can get the pump here in the states so take that off the list, so what twinplex should i get for a asus A7N8x ??? thanks...
FRAGhouse
Re: HELP ENGLISH
Wednesday, January 15th 2003, 10:29am
You should check, if you need this:
plug&cool Anschluss-Satz Eheim 1046, EUR 6,49
This is the adaption kit to connect the hose with the pump.
I don´t know if they are available in the us.
Never forget: It´s never easy to get real good stuff.
BMW 320d (E46)
gerald
Re: HELP ENGLISH
Wednesday, January 15th 2003, 10:56am
yeah ill get that too.... ok im realy close to getting the final list, all i need to find out is what twinplex to get and im going to send the email to stephan... thanks
gerald
Re: HELP ENGLISH
Thursday, January 16th 2003, 6:08am
Ok!!! i have the final list i'm going to mail this off to stephan and see what happens here it is!!
2. Twinplex Pev 1.2 Chipsatz Chipsatz plug&cool gerade
3. Festplattenkühler aquadrive, Plug & cool gerade, Blau.
5. airplex evo Einbaublende 240
6. Ausgleichsbehälter aquatube, Blau, Plug & cool gewinkelt
7. Edelstahl-Einbaublende für den aquatube
8. Beleuchtungsmodul UV EUR 11.99, für den aquatube
Other things:
plug&cool Anschluss-Satz Eheim 1250 ??? (do you make that or is it necessary)
Entkopplungsset für Eheim-Pumpen
some 90° and T -connectors (i need at least one t connector one to drain water, and im not sure how many 90 degree connectors, i leave that up to you)
thanks for all your help, if there is anything else feel free to keep me informed thanks again!
FRAGhouse
Re: HELP ENGLISH
Thursday, January 16th 2003, 11:14am
For your configuration the Eheim 1046 should be enough. The 1250 is to loud, to expensive, ... The result of several discussions in this forum is that the 1046 is sufficient for standard systems.
To drain your system I would take
- 1 pcs t-connector
- 1 pcs straight connector
- 1 pcs plug
BMW 320d (E46)
PAB
Re: HELP ENGLISH
Thursday, January 16th 2003, 2:03pm
Quoted from "gerald"
If your board has 4 holes around the socket you should think about taking the "Vierloch-Halterung Sockel A".
This is easier to install and more stable.
gerald
Re: HELP ENGLISH
Friday, January 17th 2003, 4:33am
yeah im still waiting for a reply.. i emailed the list and imed them.. so its all waiting now
gerald
Re: HELP ENGLISH
Saturday, January 18th 2003, 10:56pm
ok i got a pciture of my motherboard, i guess it does have the holes around it so i can get the better cuplex!
thore
Re: HELP ENGLISH
Sunday, January 19th 2003, 1:53am
well, actually you have drillholes, so you better discard the '3-nasen-halterung', as the '4-loch-halterung' will provide a more secure (and in my opinion even more stylish) connection. so you're ready to mail stephan.
good luck.
gerald
Re: HELP ENGLISH
Monday, January 20th 2003, 9:42am
still no word.... :-/ sigh...
