• 22.11.2026, 22:46
Drakxter
Water level going down. Normal or??
Monday, March 15th 2004, 9:54pm
Is it normal that the amount of water in your water cooling system goes down a little over time.. Becuase thats what is happening to me.
The first few times when I was testing I did have a leak or two that you could clearly see, but I learned from my mistakes and in the final setup there are no leaks (That you can see or feel.), yet the amount of water in the system goes down a bit over time.
Is this normal. Maybe becuase of air in the "radiators"?
Its not that much water thats gone missing, and its been happening over 3-4 weeks.
I am using Plug and Cool, by the way.
Thanks.
TaK47
Re: Water level going down. Normal or??
Monday, March 15th 2004, 10:06pm
It's normal!! But it shouldn't be to much!!
greetz TaK47
thetruephoenix
Monday, March 15th 2004, 10:10pm
That's nothing unnatural, don't worry.
Some water always diffuses through the tubes, even those used by the P&C-system. Also, there could be some air bubbles within the system(most likely found in, as you guessed, the radiator).
Filling in some water every half year will do the trick, there's no way to avoid some water drain over time(at least not to my knowledge). The smaller your reservoir, the more often you should refill some. If you use an Aquatube some months still will be enough.
Drakxter
Tuesday, March 16th 2004, 7:10pm
Thanks a lot :)
I was thinking it was something like you said, but its nice to have it confirmed.
Manuel_aka_MDK
Tuesday, March 16th 2004, 7:29pm
That´s correct, you´ll have a little water-loss trough the time. The waterlevel of my AT has fallen approximately 2cm during 7 months... ;)
CU
skylink
Wednesday, March 17th 2004, 12:48am
Quoted from "Onkel"
CU
Correct. I made the same experiences. After 5-6 months I refilled approx. 3cm in my AT. So, don't worry... :)
AC Komplett-Wakü in Lian-Li PC70 Athlon 2400+ 2x256 Twinmos/Winbond Barracuda V 80GB Abit NF7 Rev.2 Sapphire 9800pro
Wednesday, March 17th 2004, 1:23am
Quoted from "skylink"
...be happy 8)
neworder
Wednesday, March 17th 2004, 8:40pm
Quoted from "Shoggy"
...be happy 8)
nee das heisst doch " trink ONKO " ::)
GBT GA8INXP/P4-3,06GHZ/Radeon 9600 PRO/all cooled by AC INTEL lNSIDE IDIOT OUTSIDE
Drakxter
Friday, March 19th 2004, 12:00am
Ok ok, I wont worry then :)
