• 07.11.2026, 16:36
cyberexcite
aquastream
Saturday, June 26th 2004, 2:40pm
so yesterday we started to install a watercoolsystem everithing went good untill after we hat filled the system with water .
we gave the mainboard back his powerconector and tried to boot no mainboard :'( :'(.after a long time we gave up .
so this morning again i tried .
the result is that mainboard works fine but the aquastream controller gives only a red light .not flashing just red .
so my answer is what could it be or eventually is it possible to mount the pump without the controller straight to the powersuplly .
Katzenfreund
Re: aquastream
Saturday, June 26th 2004, 2:44pm
Did you connected the Aquastream and the Mainboard-FAN-Controller?
pharao
Re: aquastream
Saturday, June 26th 2004, 3:00pm
Quoted from "cyberexcite"
no. definitely not.
cyberexcite
Re: aquastream
Saturday, June 26th 2004, 3:23pm
Quoted from "Katzenfreund"
yes i did it true an aerogate controller
cyberexcite
Re: aquastream
Saturday, June 26th 2004, 3:25pm
the wierd thing is that i could juse it yesterday to fill the system with the jumper on it and even now that dosn't work anymore why the hell and did change annything to the configuration
Katzenfreund
Re: aquastream
Saturday, June 26th 2004, 3:31pm
Please connected the Aquastream to your COU-Fan-Controller on your Mainboard.
Re: aquastream
Saturday, June 26th 2004, 4:08pm
Maybe your mainboard or the BIOS has a fan speed monitoring and prevents the system to start if there is no signal.
When you connect the fans to a fan controller the mainboard isn't able to detect the speed of them and thinks there are no fans connected...
Just give it a try ;)
mike97
Re: aquastream
Saturday, June 26th 2004, 4:34pm
http://www.infotektur.com/demos/babelfish/de.html
cyberexcite
Re: aquastream
Saturday, June 26th 2004, 5:49pm
i did that and same result .
Clark
Re: aquastream
Saturday, June 26th 2004, 6:00pm
Do you still have your old CPU FAN?
Put it on the CPU FAn pins and try if your PC is now working...
Re: aquastream
Saturday, June 26th 2004, 6:17pm
As cyberexcite mentioned before: the board is working but the aquastream does not. So, everything is fine with the pc itself.
The problem is the aquastram or the controller.
Have you tried it with and without the jumper? Same problem with an other pc?
cyberexcite
Re: aquastream
Wednesday, June 30th 2004, 7:54pm
so thx guys but i didn't had the time to verify the aquastream but his mainboard is now for chure dead there was a wire between mainboard and case , that made a contact and i installed new mainboard with 220v pump and problems solved .
