• 09.10.2026, 22:42
Gomjaba
Brauche einen Kuehlblock fuer eine Raidkarte
Monday, December 8th 2008, 6:05pm
Ich habe schon in mehrfachen Foren nachgefragt, vielleicht kann hier mir einer weiterhelfen.
Ich kopiere hier einfach mal was ich geschrieben habe .. wenn es auf Deutsch besser ist sagt bescheid dann uebersetze ich es noch einmal (bin nur grad faul :P).
Yea sounds silly, but I have several raid cards and those Adaptec 5 series gets about 100 degrees which is apparently fine according to Adaptec but my sound cards doesn't appreciate the crispy winter tan ..
I am currently planning in building my first water cooling system and why not a raid card ey :)
Anyway, the card has two holes above and below the heatsink.
The holes are 4.5cm / 45mm / 1.773inch apart.
Can anyone / someone suggest a water cooling block which should fit on that ? I was thinking about a North Bridge cooling block but it appears the standard holes are a bit too far apart.
Any help is appreciated.
Here a few pictures from both sides
The distance from the circuit board to the heatsink is about 3mm ....
Max_Payne
Re: Brauche einen Kuehlblock fuer eine Raidkarte
Monday, December 8th 2008, 6:10pm
--> http://www.forumdeluxx.de/forum/showthread.php?t=479880
--> AC Twinplex classic/pro/xt (di) --> MSI P35 SB
Greetig Max Payne
Gomjaba
Monday, December 8th 2008, 7:19pm
Quoted from "Max_Payne"
Greetig Max Payne
He supi - danke schoen ....
Gomjaba
Monday, December 8th 2008, 7:25pm
Quoted from "Gomjaba"
Ich bin wahrscheinlich zu bloed aber kann dieses block nicht finden :/
gr3if
Monday, December 8th 2008, 7:46pm
http://www.aqua-computer-systeme.de/shop…85c2dc95ed3775a
http://www.aqua-computer-systeme.de/shopsystem/product_info.php?cPath=7_10_241&products_id=1779&osCsid=b08300b0bfb2cc59c85c2dc95ed3775a
http://www.aqua-computer-systeme.de/shopsystem/product_info.php?cPath=7_10_241&products_id=1776&osCsid=b08300b0bfb2cc59c85c2dc95ed3775a
Gomjaba
Monday, December 8th 2008, 7:48pm
Danke Euch allen fuer die Schnelle Hilfe ;D ;D
Monday, December 8th 2008, 7:58pm
Gomjaba
Monday, December 8th 2008, 11:34pm
Quoted from "SeYeR"
Dieser hier??
http://www.aqua-computer-systeme.de/shop…b1a2f4d[/quote]
Auch nicht schlecht ...
