You are not logged in.
Quoted
Guys.......DON'T feed your i680 chipset more than 1.8Volts.......I "lost" the internal PCI-E controller of it.......With a PCI VGA, mobo works OK but when I plug a PCI-E in slot 1, it doesn't boot...... A night was shuted down OK and the next morning didn't boot up.....
Quoted
CPU Vcore:1.55volt
DDR Voltage:2.25volt
DDR ref Voltage:0
NB DDR ref Voltage:0
CPU VVT Voltage:1,4volt
NB Voltage:1.5volt
SB Voltage:1.7volt
Hypertransport Voltage:1.4volt
Dont Forget !! cooling your PWM and NB chipset Good Luck Freind
hier ist aqua computer gefragt ob es schon nen chipsatz kühler und kühler für die spannungswandler gibt dann kann ich endlich auf wasserkühlung umsteigen
