You are not logged in.
Quoted from "Man_In_Blue"
Schon versucht...nix gebracht...
Man In Blue
Quoted
> Thank you for contacting Intel(R) Technical Support.
> We understand you are having problems with an error message during boot
> up.
> Remove the RTC (Real Time Clock) battery and leave it out for 20 minutes.
> After this period of time, insert the battery back in and turn the system
> back on; if it displays POST messages, go into BIOS Setup Utility by
> pressing <F2> during the boot process. Once in the BIOS setup utility,
> press <F9> to restore BIOS default settings. Reset any customized BIOS
> settings. Clear all DMI event logs, which are located in the
> Advanced/Event Log Configuration section of the BIOS Setup utility. Press
> <F10> to save the new settings and reboot the system.
> Update your motherboard BIOS.
