• 07.11.2026, 17:30
Arvosesh
Bitte klaert mich auf.....
Saturday, December 14th 2002, 5:25am
Nein, nicht was ihr jetzt denkt. :P
Ich hab auf ner Website dies hier gefunden.
Pump problems?
In I/O letters column #14 somebody asked you about the magnetic field of the PC speaker inside the computer case messing up hard drives.
On German watercooling fora, the newest buzz is that the magnetic field and the current induced by water pumps are harmful to computer circuitry and hard disks. Since I don't know enough about this to say whether this is true or just another "you absolutely need these copper RAM-coolers with a noisy 40mm fan" cr*p, I turn to you.
The most used water pumps in German water cooling rigs are by the company Eheim. A guy in a German water-cooling forum used the following setup:
Pump: Eheim 1048
Probe: 4 windings of 2 cm diameter copper wire
Sennheiser UPM-550 level meter.
The results:
Directly at the pump's casing (in mVeff)
On top: 4 mV
At the side: 7 mV
Back: 1 mV
Front: 0.6 mV
At a distance of 8cm
On top: 0.7 mV
At the side: 0.2 mV
Back: 0.2 mV
Front: 0.2 mV
Do you think that this is indeed harmful to a computer's innards? Most watercooling freaks in Germany now shield their pumps.
Joachim
Answer:
The electro-magnetic radiation from a pump might be harmful, if you've got a nasty sparky brush motor in your pump. I strongly doubt magnetically coupled pump motors (see this review for more information on them) pose any threat, though. Their external magnetic field is laughably small compared with what's needed to wipe a floppy disk, much less a hard drive, and the induced voltages you mention are a long, LONG way below the one-point-something volts that's the lowest signal voltage that I think you'll find anywhere in a modern PC. Unless something in the PC's really, really good at picking up these emissions, and really, really sensitive to noise, I don't think you'll see any effect.
iss die pumpe nun gefaehrlich? ich frag weil einer meiner Kumpels
ne 2800l/h pumpe reinbaun will....warum weiss ich auch net...
Apfeltasche
Re: Bitte klaert mich auf.....
Saturday, December 14th 2002, 11:34am
also ne 2800l/h pumpe ist absoluter quatsch!
Ob es die platten stört? ja das ist glücksache! Ich würde mal schätzen dass von 200 bis 300 leuten die ihre pumpe unter die platten bauen 1 probs kriegt! Ich weiß ja nicht wie stark diese 2800l pumpe strahlt, bei den eheims ists aber nicht wirklich ein problem!
wenn du merkst, dass es probleme gibt kannst du sie immernoch in MU-Metall bauen/verkleiden.
Du kannst die pumpe ja mal anschalten und an den monitor halten! wenn du dann bildstörungen bemerkst, heisst das dass die pumpe dir schon ärger machen könnte!
....ist aber eher unwahrscheinlich
dasc1mt
Saturday, December 14th 2002, 2:53pm
Die Werte kommen mir ja irgendwie bekannt vor. ;D
KTM-Power
Saturday, December 14th 2002, 3:19pm
ich würde sagen nicht nur die werte sondern auch der text ::)
dasc1mt
Saturday, December 14th 2002, 3:44pm
Ich muss gestehen: ich hab's net vollständig gelesen ::)
Da wird sich Lothar aber freuen ;D
Storm
Sunday, December 15th 2002, 12:11pm
Also ich hab das gerade ausprobiert mit Pumpe an Mónitohalten!
Bei mir hat das richtig gute Bilstörungen gegeben! Das ganze bild ist hin und her getanzt!
Ich hab die 1048!
Gruss Storm
KTM-Power
Sunday, December 15th 2002, 1:43pm
Quoted from "Storm"
Ich hab die 1048!
Gruss Storm
na ja durch das feld was die eheim verursacht ;)
kauf die mal mu-metall und machst dann nochmal
mal sehen ob es immernoch so ist ;D ;)
(bei ist es nun nicht mehr weil das mu das feld stark abschwächt)
