• 05.11.2026, 06:10
x-stars
Mail-Server-Prob??
Saturday, June 5th 2004, 5:41pm
ich wollte Stephan gestern eine E-Mail schicken, kurz darauf kam eine E-Mail mit nem Mail-Daemon-Fehler zurück, dass die E-Mail nicht zugestellt werden konnte.
Die Fehler-E-Mail lautet wie folgt (hab den Rest weggelassen, da kommt nur noch die Nachricht, die ich eigentlich habe schicken wollen):
Quoted
|------------------------- Failed addresses follow: ---------------------|
<xxxxxxxxxx@xxxxxxxxx.de>
  550 Mailbox quota exceeded / Mailbox voll.
&#124;------------------------- Message text follows: ------------------------&#124;
Received: from filter01.aul.t-online.de ([127.0.0.1]) by localhost
with smtp id 1BWbCb-1QWvEu0; Sat, 5 Jun 2004 15:27:13 +0200
Received: from mailin07.aul.t-online.de [172.18.16.135] by filter01.aul.t-online.de id F9S4QN3X outgoing id S0FAGI38;
  05 Jun 2004 15:27:13 +0200
Received: from moutng.kundenserver.de ([212.227.126.177]) by mailin07.sul.t-online.de
with esmtp id 1BWbCV-1rXI2K0; Sat, 5 Jun 2004 15:27:07 +0200
Received: from [212.227.126.146] (helo=mxng03.kundenserver.de)
by moutng.kundenserver.de with esmtp (Exim 3.35 #1)
id 1BWbCV-0007NO-00
for xxxxxxxxx@xxxxxxxx.de; Sat, 05 Jun 2004 15:27:07 +0200
Received: from [213.165.64.20] (helo=mail.gmx.net)
by mxng03.kundenserver.de with smtp (Exim 3.35 #1)
id 1BWbCV-0005AP-00
for stephan@aqua-computer.de; Sat, 05 Jun 2004 15:27:07 +0200
Received: (qmail 26415 invoked by uid 65534); 5 Jun 2004 13:27:06 -0000
Received: from dialin-80-228-14-119.ewetel.net (HELO PC2) (80.228.14.119)
 by mail.gmx.net (mp004) with SMTP; 05 Jun 2004 15:27:06 +0200
X-Authenticated: #2269401
Message-ID: <002d01c44b00$deaba2d0$0100a8c0@PC2>
To: <stephan@aqua-computer.de>
Subject:
Date: Sat, 5 Jun 2004 15:27:37 +0200
MIME-Version: 1.0
Content-Type: multipart/alternative;
boundary="----=_NextPart_000_002A_01C44B11.A1DC40B0"
X-Priority: 3
X-MSMail-Priority: Normal
X-Mailer: Microsoft Outlook Express 6.00.2800.1409
X-MimeOLE: Produced By Microsoft MimeOLE V6.00.2800.1409
X-Provags-Forward: stephan@aqua-computer.de -> xxxxxxxx@xxxxxxxxx.de
X-TOI-SPAM: n;1;2004-06-05T13:27:13Z
X-Seen: false
Ich hab mit Dino geredet, der meinte MEINE E-Mail-Box sei voll (siehe oben), daraufhin ahb ich den Spam-Ordner, sowie alle nicht benötigten E-Mails sowohl im Mail-Proggie,. als auch direkt aufm Server gelöscht (waren nichtmal annährend 550) und dann nochmal die E-Mail abgeschickt, und wieder kam die Fehlermeldung zurück. Woran kann das liegen, da alle anderen E-Mails (zu anderen Emüfängern) einwandfrei ankommen)??
cya
x-stars
edit : private Emailadressen von AC müssen hier nicht auftauchen. Danke.
Chewy
Re: Mail-Server-Prob??
Saturday, June 5th 2004, 6:14pm
Hast du mal versucht die Mail über das Web-Menü zu senden? Wenn sie dort auch nicht ankommt liegt der Fehler wohl bei GMX, Schlund oder T-Online ;D
Wie sieht es mit anderen Adressen aus? Geht nur die Adresse von Stephan nicht bzw. allgemein keine Adressen bei Schlund und/oder T-Online? Kannst mir ja testweise versuchen eine zu senden:
Ich denk eher der Fehler liegt irgendwo beim Provider und nicht bei dir zumal du wohl bestimmt vorher schon Adressen bei diesen Providern angeschrieben hast ohne Probleme.
x-stars
Saturday, June 5th 2004, 9:30pm
OK, hab dir mal ne Test-E-Mal geschickt, ansonsten werd ichs mal übers Web-Interface versuchen.
THX
x-stars
Saturday, June 5th 2004, 9:49pm
Auf dem T-Online Account ist was angekommen. Hattest du auf den anderen auch etwas geschickt?
x-stars
Saturday, June 5th 2004, 9:59pm
Nein, an die andere nicht - dafür aber übers Web-Interface an Stephan. Ratet mal was zurückgekommen ist ::) - richtig, wieder eine E-Mail mit dem Mail-Daemon :'(.
Quoted
&#124;------------------------- Failed addresses follow: ---------------------&#124;
<stephan.wille@t-online.de>
Wessen Mailbox ist denn voll? Dino meinte, das wäre meine, da deren Server
a) eine solche Meldung nicht verschicken dürfte und
b) die sehr viel mehr Speicherplatz für E-Mails hätten,
aber ich habe daraufhin alle Spam und sonstigen E-Mails von mir gelöscht, trotzdem kommt das noch. Kann es sein, das tatsächlich Stephans E-Mail-Box voll ist? Oder liegt der Fehler irgendwo dazwischen (bei dem/den ISP, Netzen oder sonstwas?).
cya
x-stars
DerDaniel
Saturday, June 5th 2004, 10:08pm
hmmm, diesen Fehler hatte ein Kumpel von mir vorgestern...
Er wollte mir eine Zip Datei senden und bekam die Meldung ausgespuckt... Daraufhin hab ich meine Mailbox geleert und er konnte mir den Anhang senden, bzw ich ihn empfangen...
also nehm ich mal an, dass Stephans Mailbox dicht is... und nicht deine...
Saturday, June 5th 2004, 10:14pm
OK, ist mit Sicherheit die Mailbox von Stephan, die dicht ist, denn deine kann es wohl kaum sein nachdem du alles geleert hast ;)
Ich habe jetzt eine Test-Mail geschickt und mal schauen ob ich ebenfalls den Fehler bekomme.
--- edit ---
OK, Problem gelöst: habe die Fehlermeldung ebenfalls erhalten. Das Postfach ist voll. Auf deiner Seite funktioniert also alles reibungslos. Wenn's was wichtiges ist soll es z.B. Dino weiterleiten oder du greifst ganz altmodisch zu Stift und Papier ;D
Quoted from "x-stars"
a) Das Postfach liegt nur eben nicht auf dem AC-Server sondern es ist nur eine Weiterleitung zu T-Online und diese senden dir direkt den Fehler zu so dass der AC-Server ihn gar nicht abfangen kann.
b) evtl. ist das Postfach mit Mails zugemüllt, die einen ziemlich grossen Dateianhang haben ;D (Ich war's nicht *g*)
x-stars
Saturday, June 5th 2004, 10:19pm
Na, so wichtig, als das ich per Brief schreiben müsste, ist es nicht. Werd das mal an Dino schicken und ihn bitten das weiterzuleiten.
THX
x-stars
Y0Gi
Sunday, June 6th 2004, 5:38pm
solche meldungen kommen vom server, an den du die mail geschickt hast, nicht von deinem (vgl. "received from"). dein server würde dir das direkt mitteilen und wahrscheinlich per fehlermeldung über dein mail-programm offerieren.
