• 14.10.2026, 12:36
Nutman
Aqualis holder only in black acrylic?
Tuesday, October 30th 2012, 12:37am
Dear Aqua Computer
I am going to purchase the Aqualis reservoir aswell as an AC D5 and pump adapter for the pump to be used with the Aqualis reservoir.
I will also purchase the yellow decouplers to eliminate vibrations coming from the pump, but I have heard that mounting the entire setup only using the yellow decouplers will cause the setup to tilt away from the surface is it mounted on - because of the weight.
I know you're making the reservoir holder:
Any chance of EVER getting a version made from clear acrylics instead of black?
Or will I have to make my own?
/MotoMazz
Tuesday, October 30th 2012, 9:56am
Very unlikely that this part will be available in another color.
