• 29.11.2026, 00:32
gez09may
Confusion Aquacomputer aqualis DDC 100 ml
Friday, June 13th 2014, 7:03pm
Hi All
Im attempting to build my first water-cooled pc and have a question. I bought the Aquacomputer aqualis DDC 100 ml and installed a Laing pump without any problems but on there is no water Inlet Outlet direction stamped on the reservoir base so not sure what hole does what?
If anyone could shed some light on it i would appreciate it.
Gerry
Rostiger
Saturday, June 14th 2014, 6:06am
Hi Gerry,
the left hole is the outlet, klick in the AC - Shop on the pikture of your Device will show you what is In and Out...
Jakusonfire
Saturday, June 14th 2014, 6:58am
On centrifugal pumps like the DDC and D5 the port closest to the edge will always be an outlet
gez09may
Saturday, June 28th 2014, 5:03pm
Hi there
This is the system i have…
Just need confirmation which is the inlet and which is the outlet…
This post has been edited 1 times, last edit by "gez09may" (Jun 28th 2014, 5:09pm)
Jakusonfire
Sunday, June 29th 2014, 3:58pm
Inlet on right, outlet on left
This post has been edited 1 times, last edit by "Jakusonfire" (Jun 29th 2014, 4:04pm)
