• 24.11.2026, 07:10
FIREFLY-SERENITY
Can you assign a profile to f1 f2 f3 of f4
Monday, August 24th 2015, 10:54pm
Hi Can you assign a profile to f1 f2 f3 of f4
Tuesday, August 25th 2015, 11:44am
Not directly. You can only jump into the menu where you select the specific profile but it is not possible to select and activate a profile with one key.
Using the programmable keys would also make not much sense for this because if you press the enter key you can already select the four profiles from the main menu:
FIREFLY-SERENITY
Tuesday, August 25th 2015, 3:49pm
ok thanks :)
