• 09.10.2026, 00:43
spalex
Quick and easy question about flow sensors and the Aquero 6
Tuesday, December 27th 2016, 10:42am
Hi guys, I have just found out about this hardware and I am really pulling my dick over it.
Probably going to buy one the minute my query gets cleared up .
1) Are all the temp sensors that are included, and the temp sensors that I will buy from Aquacomputer for the Aquero 6. Are they already calibrated?
2) I think Aquacomputers flow sensors look ugly and I would like to use something like this
http://www.bitspower.com/html/product/pr…d=235&kind2=235
Is that going to be a problem? Can I just plug it in and it will work straight away?
RE: Quick and easy question about flow sensors and the Aquero 6
Wednesday, December 28th 2016, 1:45pm
lol, busted a gut laughing over your intro... must be a generational difference :D
1) Yes, you can plug the temp sensors in right out of the box/bag & they will work fine.
2) No, the Bitspower devices are flow indicators only, little whirly things that rotate.
You could put a little whirly thing in the loop where it is visible, and a true flow sensor in the back part of the loop where it is not visible.
spalex
RE: RE: Quick and easy question about flow sensors and the Aquero 6
Thursday, December 29th 2016, 6:26pm
No no the first few on that page I linked are flow indicators. But they also have flow sensors on that page.
Are they going to be giving out a generic signal that the aquero 6 can read? Or would I need to calibrate it?
Similar threads
