• 13.11.2026, 00:17
cmsj
Execute commands on profile change
Tuesday, November 3rd 2020, 1:37pm
Hi folks!
Is it possible to get Aquasuite to execute a command when a profile is changed? (either through an automatic rule, or via the system tray selector)
I have different RGB settings for different profiles, and it would be nice to be able to tell OpenRGB to switch motherboard/ram/keyboard/mouse RGB settings when the aquasuite profile changes.
If this isn't a feature already, could it be added?
Many thanks!
Chris
Tuesday, November 3rd 2020, 1:55pm
You can use the playground notification module.
as data souce select the current aquasuite profile.
for each profile you have to build a notification.
in the notification you can set the action for your external application
cmsj
Thursday, November 5th 2020, 9:18pm
That's very interesting, thanks!
