• 15.11.2026, 12:10
cptninc
How can I create this lighting effect with a Farbwerk60?
Friday, December 24th 2021, 5:44am
I'd like my addressable RGBs to have a breathing effect for coolant temps from 0-36C, a solid gradient from 36-40C, a solid color from 40-44C, and then solid color + flashing from 45C and above.
All of the solid stuff is easy to do via a simple Color Switch controller with multiple temp limits. How do I add the breathing before the Color Switch takes over?
This post has been edited 1 times, last edit by "cptninc" (Dec 25th 2021, 12:43am)
Friday, December 24th 2021, 11:24am
Profiles.
Setup 3 profiles on your 360, then use Global profiles in the Playground to swap between them depending on your system's status.
This post has been edited 2 times, last edit by "InfoSeeker" (Dec 24th 2021, 11:26am)
cptninc
Tuesday, December 28th 2021, 2:29pm
Thanks! Will give this a shot this week.
