You are not logged in.
Quoted from "Shoggy"
- unused sensors will be hidden in the diagram
- all files have been sorted to suited folders (firmware, help, picture, script...)
- you can customize the look and feel via the files GlobalSkinSettings.xml, AquaeroSkinSettings_????.xml
- you can use your own grpahics for checkbuttons, save them to the picture folder and edit the xml file
- you can switch between styles (0, 1, 2)
Quoted from "Ze@lot"
shoggy i have had a problem with this updated version 4.34 shown above for some reason it will not change to english. the one i downloaded from hard forum works ok but this link above seems to be missing a file.
Quoted
... Ah now I saw Stephans introducement....
Quoted from "rapid20"
@ Katzenfreund
How about using the English expression introduction![]()
