• 29.09.2026, 15:49
J-C
Translate firmware
Monday, October 16th 2006, 9:11pm
how to edit the firmware to translate it into French?
In aquaero os loader i found language.lng. But is this possible to do it for aquasuite?
Re: Translate firmware
Monday, October 16th 2006, 9:22pm
Check the folder aquasuite\database. There you will find a MS Access database called aquasuite.mdb. It contains the strings and you can add a new language.
Monday, October 16th 2006, 11:30pm
Just to improve your understanding:
The aquasuite will include the new language in the firmware of the aquaero if you flash the aquaero again with the actual firmware after selcting the new language in the aquasuite.
The database can be edited with Access as Shoggy said.
