• 12.11.2026, 17:18
Darkled
Help me choose
Wednesday, December 24th 2008, 12:53pm
Hello to all,
my German are a little rusty so i would like your help regarding the products to choose.
I would like to buy the aquaero in order to monitor water temps, water flow, water level and control the fans.
as i understand i would also need the aquastream ultra pump. and the tubemeter usb.
Do i need any extra cables or anything else?
The aquastream ultra pump shows water temps right?
fox3
Wednesday, December 24th 2008, 3:51pm
I am not sure you "need" a tubemeter, though it is a nice feature to have along with with the aquatube resevoir and aquaero.
The Aquastream Ultra XT is able to give water temperature reading indirectly.
Darkled
Thursday, December 25th 2008, 8:35pm
what do you mean indirectly?
doesn't it work with aquaero? will i be able to get water temps through the pump?
tubemeter only works with aquatube reservoir?
fox3
Thursday, December 25th 2008, 10:15pm
Yes the Aquastream works with the aquaero and/ or aquasuite through usb or aquabus and can give the water temp through the pump. It also has an external temp plug for a sensor that makes direct contact.
rocky61
Wednesday, December 31st 2008, 12:14am
The Tubemeter is a very nice product. I have one in my Aquatube along with the aquajet. The best feature is that it monitors your H20 level and shuts down your sysytem in the event of low H20 level. It also has a nice little stobe light.
Similar threads
