• 22.11.2026, 20:44
psychotik2k3
What about aquastream XT configuration with the software shutdowned ?
Tuesday, March 31st 2009, 4:58pm
Hi i have an aquastream XT and i made some setups using the aquasuite software, like my fans are off until a certain temperature etc etc.
i saved the configuration to the pump using htje menu
what happens for example if i stay in bios setup, so without the aquasuite software running and the processor running at 100%.
will the pump activate the fans or will it stay just in it's default mode with fans off ???
it's important to know because what's happens if i have a blue screen of death ???
thanks
Top_Nurse
Wednesday, April 1st 2009, 2:02am
The pump's firmware should run as programmed whenever there is power applied to the pump.
psychotik2k3
Wednesday, April 1st 2009, 7:29am
cool
i was a bit afraid yesterday when my home computer wasn't available anymore on remote access.
thanks TN
Similar threads
