• 08.10.2026, 04:48
SNTmods
No Fan Power on Headers 1 and 3
jeudi 4 novembre 2004, 08:23
There seems to be no available power to fan headers 1 and 3 on the Aquaero, 2 and 4 work fine. I am currently operating under the 3.22D firmware too, any help would be appreciated since Im doing this for a customer of mine.
-Dan
Was an early adopter of Aqua-Computer watercooling in the U.S.
Re: No Fan Power on Headers 1 and 3
jeudi 4 novembre 2004, 11:40
If there is no power on two channels, please reset the EPROM of the aquaero by pressing the set-key for 3 seconds on power on.
After that all outputs should have maximum power. If not there is a hardware problem on the aquaero board.
Chewy
jeudi 4 novembre 2004, 11:49
but be patient... NOT longer than 3 seconds... (!!!) the second part of the erasing function is to kill the firmware from the aquaero and this would be the last "beep" from your ae....
you should see a message "erasing eeprom...." and nothing further.
SNTmods
jeudi 4 novembre 2004, 12:06
Citation de "Stephan"
The EPROM reset doesnt even seem to work. I never get the "warning" statement.
And now the Aquaero turns off completely after 15 seconds or so after displaying the first title screen.
-Dan
Chewy
jeudi 4 novembre 2004, 14:27
turn off the power. disable the ae from its power source for at least a few minutes. restart.
does this works or did you even try in this way ?
SNTmods
vendredi 5 novembre 2004, 00:47
Citation de "Chewy"
This doesnt work for me at all, I still cant reset the EEPROM.
-Dan
x-stars
vendredi 5 novembre 2004, 16:28
The only opportunity will be in sendig the Ae to the support for RMAing :-/.
cya
x-stars
