• 15.11.2026, 04:30
Guffen
Flow sensor
vendredi 12 août 2005, 02:30
I have a problem that the l/hour at my aquaero is different from the software.
The Software says 60 l/hour the aquaeros says 110 l/hour? Whats the problem.
Whati is the calibration value for impulse / liter under flow sensor in the new aquaero software. Mine stands at 609 I think I moved it by accident.
Any one has any help on this things.s
J@FF@
Re: Flow sensor
vendredi 12 août 2005, 09:51
Did you drill out the Flow Sensor or not?
there are different values if its drilled out.
609 is to much.
jaydee
Re: Flow sensor
vendredi 12 août 2005, 12:19
For the flow sensor digimesa, which you can buy here at aquacomputer, the impulse value must set to 509 imp.
Tiak
Re: Flow sensor
dimanche 21 août 2005, 15:51
At first, there is a special section namend "English forum" :>
Is the cable in the right order at the aquaero?
Changed entrance and exit from the Flow sensor?
MfG Tiak
