• 07.10.2026, 00:17
Max_Payne
Aquasuite: Fehlermeldung *erledigt*
mardi 25 juillet 2006, 18:46
Hi Jungs,
ich habe ein kleines Problem mit meinem Aquaero, und zwar wird beim Start folgende Meldung ausgegeben:
Code source
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.IndexOutOfRangeException: Index was outside the bounds of the array.
   at aquasuite.frm_aquaero_Rev4.LoadGlobalSettings()
   at aquasuite.frm_aquaero_Rev4.AquaeroLoadSoftwareSettings()
   at aquasuite.frm_aquaero_Rev4.OnLoad(EventArgs e)
   at System.Windows.Forms.Form.OnCreateControl()
   at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
   at System.Windows.Forms.Control.CreateControl()
   at System.Windows.Forms.Control.WmShowWindow(Message& m)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
   at System.Windows.Forms.ContainerControl.WndProc(Message& m)
   at System.Windows.Forms.Form.WmShowWindow(Message& m)
   at System.Windows.Forms.Form.WndProc(Message& m)
   at System.Windows.Forms.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 1.0.5000.0
    Win32 Version: 1.1.4322.573
    CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
aquasuite
    Assembly Version: 4.39.2375.16734
    Win32 Version: 4.39.2375.16734
    CodeBase: file:///C:/Programme/Aqua%20Computer/aquasuite/aquasuite.exe
    CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
System
    CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
MyUSB
    Assembly Version: 1.0.2375.13098
    Win32 Version: 1.0.2375.13098
    CodeBase: file:///C:/Programme/Aqua%20Computer/aquasuite/MyUSB.DLL
----------------------------------------System.Drawing
    CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
Microsoft.VisualBasic
    Assembly Version: 7.0.5000.0
    Win32 Version: 7.10.3052.4
    CodeBase: file:///c:/windows/assembly/gac/microsoft.visualbasic/7.0.5000.0__b03f5f7f11d50a3a/microsoft.visualbasic.dll
SandBar
    Assembly Version: 1.1.0.2
    Win32 Version: 1.1.0.2
    CodeBase: file:///C:/Programme/Aqua%20Computer/aquasuite/SandBar.DLL
Max_Payne
Re: Aquasuite: Fehlermeldung
mardi 25 juillet 2006, 18:48
Fortsetzung:
Code source
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
Interop.JRO
    Assembly Version: 2.6.0.0
    Win32 Version: 2.6.0.0
    CodeBase: file:///C:/Programme/Aqua%20Computer/aquasuite/Interop.JRO.DLL
System.Data
    CodeBase: file:///c:/windows/assembly/gac/system.data/1.0.5000.0__b77a5c561934e089/system.data.dll
System.Xml
    CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
myTranslationClasses
    CodeBase: file:///C:/Programme/Aqua%20Computer/aquasuite/myTranslationClasses.DLL
ControlLibrary
    Assembly Version: 1.1.2375.15081
    Win32 Version: 1.1.2375.15081
    CodeBase: file:///C:/Programme/Aqua%20Computer/aquasuite/ControlLibrary.DLL
SandDock
    Assembly Version: 1.0.6.0
    Win32 Version: 1.0.6.0
    CodeBase: file:///C:/Programme/Aqua%20Computer/aquasuite/SandDock.DLL
C1.Win.C1Chart
    Assembly Version: 1.0.20044.14252
    Win32 Version: 1.0.20044.14252
    CodeBase: file:///C:/Programme/Aqua%20Computer/aquasuite/C1.Win.C1Chart.DLL
C1.Common
    Assembly Version: 1.0.20031.116
    Win32 Version: 1.0.20042.118
    CodeBase: file:///C:/Programme/Aqua%20Computer/aquasuite/C1.Common.DLL
myTCP
    Assembly Version: 0.0.0.0
    Win32 Version: 0.0.0.0
    CodeBase: file:///C:/Programme/Aqua%20Computer/aquasuite/myTCP.DLL
v18h2yth
4ar-rmsp
************** JIT Debugging **************
To enable just in time (JIT) debugging, the config file for this
application or machine (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the machine
rather than being handled by this dialog.
Bisher ausprobiert:
[*]EEPROM-Reset
[*]Neuinstallation Aquasuite / NET.Framework
P.S. Am System wurde nichts geändert und gestern ging es noch...
Edit: Nach einem Klick auf Continue funktioniert alles tadellos...
Gruß Max Payne
Max_Payne
mercredi 26 juillet 2006, 16:31
Keiner eine Lösung oder einen Tipp an was das liegen könnte ?
Denn diese Fehlermeldung ist schon sehr lästig...
Gruß Max Payne
JaR
mercredi 26 juillet 2006, 16:36
Hm... obwohl... doch, eines funktioniert ja immer:
Windows neu installieren!! ;D ;D
badger badger badger ...
Max_Payne
mercredi 26 juillet 2006, 16:39
:-/ Das möchte ich um jeden Preis vermeiden, denn auf dem PC ist die komplette Fernadministration installiert sowie alles was ich für den täglichen Gebrauch benötige ...
Zur Not muss es halt jetzt so weiter gehen bis der Rechner im Herbst erneuert wird.
Gruß Max Payne
mercredi 26 juillet 2006, 16:56
Vielleicht hilft das:
aquasuite deinstallieren,
den kompletten ordner aquacomputer in Programme löschen,
aquasuite neu installieren,
alternativ lösche mal alle *.xml dateien im aquasuite ordner + unterordnern.
Sebastian
Max_Payne
mercredi 26 juillet 2006, 17:04
Das war die Lösung, die beiden XML-Dateien waren der Überltäter...
Dankeschön Sebastian :D :D
Gruß Max Payne
JaR
Re: Aquasuite: Fehlermeldung *erledigt*
mercredi 26 juillet 2006, 18:17
Werden in den XML Dateien auch die Farbinformationen gespeichert, die beim ersten Start aus den Systemfarben zusammengestellt werden? Das hatte nämlich bei mir mal zu dem Problem geführt, dass die Schrift in der aquasuite schwarz auf schwarz war.
