• 09.10.2026, 02:22
Top_Nurse
New! AC Inline filter
vendredi 13 mars 2009, 08:49
Found something intriguing in the shop today. It is an inline filter which sounds like a good idea when you are using products like the Cuplex XT and XT DI with very small nozzles.
It has ball valves, a stainless steel mesh filter, mount, and can even be lit up like the Aquatubes. More information can be found here. Appears to be 29.9 Euro and if you live outside the EU it is 24.22 Euro. It's made out of black delrin, plexiglas, and has G 1/8 threads.
Ce message a été modifié 2 fois. Dernière modification effectuée par "Top_Nurse" (17 avril 2009, 13:11)
SquirrelM
vendredi 13 mars 2009, 21:23
What size is this and what size is the faceplate?
Top_Nurse
samedi 14 mars 2009, 07:09
Have no idea as it isn't listed anywhere. However, I would estimate it is about 75-100mm long and about 50-75mm wide. That is based on knowing the size of some common components like G 1/8 threads in the back of the unit and the size of the ball valves. Maybe someone who has actually seen one will come by and tell us the dimensions. I decided to order one just because I have had my XT jets get clogged before from contaminants in the loop.
Discussions similaires
